![]() | Home > Td5 > Coolant flush and Hose replacement |
Joel Member Since: 18 Oct 2020 Location: Rotherham Posts: 76 ![]() ![]() ![]() |
My TD5 seems to have baby diarrhoea coolant.
I’m going to drain and flush the system. I plan to change the hoses as well, but what else is likely to need changing as well? Don’t want to get in there and find other stuff needs doing. Which hoses do people recommend? OEM or silicone? Thanks in advance. |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
I can't answer your question, but while you're at it you also might want to replace this short hose between the heater circuit and the oil cooler. It sits just below the turbo:
![]() Click image to enlarge Part no for MY05 15p Td5 is PBH101980. One doesn't read often about it, but apparently it is not uncommon for it to burst since it suffers from the turbo heat. I encountered a Td5 with the issue when on holiday two years ago. I'm not that knowledgeable, but 'baby diarrhoea' sounds like a problem with oil mixing with coolant. That won't be solved just by flushing and replacing the hoses I'm afraid, and having mentioned the oil cooler above: it might just be the culprit (the cooler, not the hose). I hope for you that I'm wrong. Joris Antares Treadwell, a MY06 110 Td5 in Chawton White |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 224 ![]() ![]() ![]() |
Hi Joel,
Replace the thermostat. I did one the other day for a Td5 customer at the local LR Indi garage, and it was full of gunge and rusty water. Easy to do, just 3 hose clips, 👍 Ashby Andy |
Thanks all,
Slowy building up a list of bits so I can do it. |
