Home > Puma (Tdci) > 2.4tdci ‘08 lumpy idle |
The VCV - volume control valve rather than vacuum - is a very likely suspect. Darren
22nd Nov 2020 5:08pm |
cypermethrin Member Since: 15 Dec 2010 Location: Berkshire Posts: 93 |
Thanks for the replies and counsel
New VCV ordered from PF Jones and fitted by my 17 y.o. son over the weekend - he said it was quite straight forward having small hands clearly helps! Started on the 2nd attempt. Also did the pump and VCV learn using Forscan s/w and 17 quid ELM327 USB thing...no DTCs recorded either... needs a good run to ensure its all sorted - that's tomorrow ! |
30th Nov 2020 11:41am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
You could have just fitted it as it was with no programming. I did and everything was all good with it and self learns.
I used the same supplier and has been running really nice ever since - couldn’t fault them. If you get it again think about replacing the MAP & MAF Sensors. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
30th Nov 2020 6:48pm |
