Home > Modifications & Maintenance (L663) > Rails for Roof Rack - Prototype
slyttleton
United States 1986 Defender 110 200 Tdi SW Santorini Black
I'm working on a rail addition to the roof rack for added function and a bit of throwback look. Still in process getting the bends correct and the brackets aligned. Will be powder coated black when finished.
Post #867306 14th Nov 2020 3:14pm
Interesting idea. Show us a bit more detail, please. Darren
Post #867409 14th Nov 2020 8:47pm
AndrewS
I made rack rails for the frontrunner I had on my disco 4
 130's have feeling's as well you know Smile
Post #867511 15th Nov 2020 2:08pm
slyttleton
Finished the rails. I'm happy with how strong they are and that the powder coating matches well with the rack.
I used a Shapeoko CNC to design and mill the brackets out of 3/4" aluminum bar. The rails are 3/4" aluminum tube about .25" thick. Only real difficulty was getting the curves right on the brackets and the front tube. Lots of scrap from failed attempts.
Given the funky cut-out on the rack in the back for the antenna I didn't take them around the back. Still thinking about that.
Thanks,
Post #868872 21st Nov 2020 10:28pm
The brackets are very nicely done. My initial thought is that you might need more of them to support the tube if you plan on lashing anything to it, as it seems like quite long spans. Darren
Post #868923 22nd Nov 2020 10:56am
Andy_W
Would you mind telling me how you secured the roof lights into the rack frame? There is no obvious way to get under the top plate part of the frame that I can see to secure a nut? It looks great with the frame and lights
Post #882257 31st Jan 2021 10:00pm
Sepp
Germany
Looking at the mirror reflection in picture 2, they are bolted all way through the rack, if I see this correctly.
Post #882297 1st Feb 2021 7:25am
