Home > In Car Electronics > Illuminated switches |
It's very unlikely without dismantling the switch, unfortunately. I think you'll have the same problem with the switch on the left, too. Darren
21st Nov 2020 6:56pm |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 223 |
Hi Martyn,
If it’s a 3 wire switch, one wire will be earth (negative). The others would be 12v in, and switch 12v out, which also should illuminate the LED when on. So in my reckoning, if you swap these 2 wires around, the LED will always be on. I’ve got similar in the back panel above the rear door, for a rear work light. Hope I’m right, Ashby Andy 🤞 |
21st Nov 2020 7:12pm |
Martyn668 Member Since: 17 Mar 2013 Location: Cambridgeshire Posts: 135 |
I've got a couple of spare switches, so I might try it on a bench. They're only a couple of quid each.
22nd Nov 2020 12:08am |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 |
In modern cars they have an LED in the roof console. This shines onto the switches. The switches look like they actually illuminate but they don't, it is the light from above that comes on with the light switch. You don't realise until you block the light from above with your hand.
Perhaps this could be an option. You would have to find a suitable location and and also a suitable led. As for electricery, that is definitely not my field!! |
22nd Nov 2020 4:13pm |
