Home > General & Technical (L663) > Rear seat noise |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3412 |
Is the seat backs rubbing on anything?
21st Nov 2020 10:35am |
Flemincc Member Since: 21 Nov 2020 Location: Cincinnati, OH Posts: 8 |
No, it's definitely coming from where the head rest inserts. If I hit the seats I can hear the high pitch squeak right where the inserts holes are
21st Nov 2020 2:22pm |
Give them a squirt of silicon lubricant? Darren
21st Nov 2020 3:56pm |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 199 |
Solution here at 7 - 8 mins in
Seriously, silicone spray... |
21st Nov 2020 7:10pm |
Ok so it wasnt the rear seat headrest, the squeaky noise is coming from the latch where the passenger back seat locks on to. It seems to be slightly loose and is able to move on certain bumps.. any ideas on how to fix this??
24th Nov 2020 11:24pm |
On my previous RRSs the fix for this was to wrap the loop with the soft side of a velco fastening.
25th Nov 2020 11:31am |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 |
Do you have pictures, if possible, please. |
26th Nov 2020 1:53pm |
Correction. I found the culprit. My squeak is coming from
The knob for the 3rd row fan speed. If I tap On the plastic around the knob or push on that area it squeaks. It's the most annoying squeak ever! |
27th Nov 2020 11:25pm |
NewDefenderSeattle Member Since: 02 Dec 2020 Location: Seattle Posts: 17 |
Mine is doing the exact same thing! It’s actually the P bracket the rear right seat connects to.
2nd Dec 2020 3:08am |
Yep mine is the bracket for sure. Dealer is coming to get it today so they'll hopefully fix it up!
2nd Dec 2020 1:38pm |
@Flemincc I just got mine back from the shop. They said they had to put some felt behind the bracket and then secured it back in place. I guess we will see how long this lasts but it did stop the noise.
8th Dec 2020 6:52pm |
