Home > Maintenance & Modifications > Door Sill / Battery Box Corrosion
RichardBattersby
Hi,
I've noticed some corrosion at the corner of the seat box so I bought some YRM stainless sills to go in.
However, on closer inspection, I've noticed that on the passenger side there's an extra sheet of metal between the box side and the sill, it's this that's heavily corroded. See below:
This is what the drivers side looks like:
I obviously want to remove that piece of metal but as you can see, I've removed the bolts and it won't budge. How do I get it out?? Why is it just on one side? It looks like the factory were trying to fill the gap and I haven't found any pics on here or online that show this extra piece. Defender 90 HT Corris Grey Puma 2.2TDCi
Post #867696 16th Nov 2020 12:38pm
I think that's the pressing for the bottom of the battery box and it's a different arrangement on the drivers side. I'm pretty sure that the only way to remove it would be to take out the entire seat box. Darren
Post #867703 16th Nov 2020 1:13pm
lakelander
United Kingdom 2013 Defender 90 Puma 2.2 CSW Orkney Grey
I had the same problem, it looked a right mess and the seat boxes edged were beginning to crumble.So I also fitted the YRM threshes. The problem is caused by electrolysis between the aluminium panels and steel bolts pieces. When I put it together again I fitted a gasket between them ( cut up an old head gasket )and used Duralec paste as I put in the YRM stainless bolts.
Don't remember the two sides being different?
Mine is a 2013 model with unpainted sills _ thought the newer models had colour matched sills ?
Post #867711 16th Nov 2020 2:21pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Yep, the crusty bit shown in the picture on the passenger side is the battery box base which is sandwiched between the seatbox and the sill.
I recently replaced the battery box on my old '84 Ninety but did so with the seatbox still in. This was only possible as I cut the battery box into pieces in-situ before it dropped out the bottom. The replacement was a YRM ally version that I assembled in-situ too. Depends how much of a stripdown you want to do to resolve it. Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #867728 16th Nov 2020 3:41pm
Greeny
Recently replaced both seat ends on my TD5. Did a write up on the thread below.
https://www.defender2.net/forum/topic72237.html
Not sure about replacing the battery box and whether that can be done in situ or not. But by removing the seat box end everything is a lot more accessible to repair/replace.
Before and after pictures below of the seat box end replacement.
 Instagram - @Land_Rover_Defender
Post #867733 16th Nov 2020 4:15pm
