Home > Maintenance & Modifications > 110 vented disks/calipers upgrade compatibility?
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
I'm just about to start rebuilding my front axle (leaky swivels) and just wondered if the 110 vented disk and caliper upgrade is compatible with my front axle?
It has the original front axle found on a 1989 Ninety -the rear axle had drum brakes.
Thank you!
Post #867613 15th Nov 2020 9:49pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Yup.It's a straight swap,110 vented discs,& calipers,(or you can use the origional 90 calipers,but cahnge the spacer in the middle to make them the same width as 110 calipers.)& pads.
I uprated my 90 last year to this,braking is definately better,with less fade.
Marc.
Post #867680 16th Nov 2020 10:04am
