Home > Technical > Can pull out key out of ignition with engine still running
Ollie_Crock
United Kingdom 1986 Defender 90 200 Tdi HT Java Black
Hi,
I am looking for help with a weird ignition problem, with the engine still running I can pull out the key out of final rotation. Does anyone know how to fix this strange minor problem please?
Post #867564 15th Nov 2020 7:09pm
Hufflepuff
I presume this is on your 200Tdi?
If so you need to figure out if the fuel stop solenoid is at fault, or if its an electrical problem to the solenoid.
Is it possible to measure the voltage across the solenoid with the key in the on and off positions? This might give you a clue as to the fault. 2005 Td5 90 XS
1989 V8 110 CSW
Post #867576 15th Nov 2020 7:58pm
Do you mean that the engine keeps running after you turn the key to the off position and pull it out (if so, see post above), or do you means that the key can be pulled out from the barrel when it is in the engine running position?
If the latter, the lock barrel is excessively worn and needs replacing (and I believe that this is now an MOT failure fault, but may be wrong).
Post #867577 15th Nov 2020 8:09pm
Hufflepuff
Ah I misread Ollie's post. I think you are right blackwolf, the key is being removed from the barrel in the 'on' position. 2005 Td5 90 XS
1989 V8 110 CSW
Post #867589 15th Nov 2020 8:41pm
mini Anaconda
You need a new ignition barrel. Mine had this "design feature" when I bought it. BORG - Bucks & Oxon 4x4 Response Group
Post #867611 15th Nov 2020 10:42pm
jst
My 2011 vehicle had same issue, one lucas ignition barrel later and all resolved, about £70 Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #867623 15th Nov 2020 11:22pm
Ollie_Crock
Its a new ignition barrel that I put in a 1986 90 so it might be a production error.
Post #868878 21st Nov 2020 10:39pm
cee-b
I know it doesn't help, but this was pretty much standard on many Brit cars in the 70s. Along with being able start a car with pretty much any key.
Really handy if you forgot your keys - just borrow someone else's and give them back once the engine is running Rolling Eyes Not great for security though.
As said above, it sounds like it needs a new barrel.
Post #869154 23rd Nov 2020 4:52pm
roel
Use an elastic band and ty that to the light switch. It still falls out but you know where it is. Roel
2003 90 Td5 (2009-now)
Post #869184 23rd Nov 2020 6:54pm
On one of my Series Ones the ignition key is so loose it tends to fall out on bumps, so I always clip it to a tether so I can find it if it does. On one occasion I managed without realising to start the vehicle and drive off using my garage door key, which is completely different in almost every respect except size.
Post #869198 23rd Nov 2020 7:41pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Must be a design feature, get over eager on a left turn or incline and mine can drop out of it’s own accord.
I’ll get round to it.
Post #872258 10th Dec 2020 10:44am
