![]() | Home > Maintenance & Modifications > How to get the double din Dashboard fit flush back |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
3 simple steps when I did it and had the same issue. In the end had it fitted for me in teh end but the installer talked through the issues and showed me the problems.
Obvioulsy put the cables in carefully Some people remove the metal bracket that is welded to the cross bar behind as this causes clearance issues. But most importantly heat up the heater pipes with a heat gun at the back to bend them out of the way slightl. I struggled. Gave up but after seeing what he did i wish I'd have carried on. |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1231 ![]() ![]() ![]() |
I had trouble with mine too...Was frustrating tbh.
All the above makes sense. I found the Head Unit was fixed at angle which didn’t allow the assembly to move back into the area of most space. I elongated the holes in the two brackets securing it. A small angle change at the front gives a larger movement at the very back of the unit. This made a considerable difference and mine fits ( and comes out and goes back again) a treat👍 Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
Try crushing the heather vents at the back, on mine, I totally cut the centre vents out and blanked them off, I get much better air flow out of the two outer vents, drastic, but everything on mine fits perfectly.
