Home > Maintenance & Modifications > Big Brakes - Questions
bankz5152
Going to be installing a set of LOFs big brakes on my 110 soon, which Im fine with.
Though is it worth upgrading the rear brakes as well? I was thinking of using my current front discs and calipers on the rear with one of the various adaptors.
Is it worth doing or best just to leave as is?
Interested either way! Instagram @defender_ventures
Empire Tuning - Agent
Post #866994 12th Nov 2020 9:27pm
Avelingporter
Just make sure that you have the correct brake balance between front and rear. No good having all on the front and not enough on the rear or visa versa. Ask LOF what they recommend to match their brakes on the front. What you don’t want is to find out it is unbalanced in an emergency. By then it will be too late.
Post #867039 13th Nov 2020 8:48am
roel
It's better to have too much on the front then too much on the rear.
I don't know if you have abs (i don't) but if you have too much on the front the abs will work on the front axle and you will get maximum breaking out off all anyway.
If you have too much at the rear you might turn around in a corner while breaking quickly. Roel
2003 90 Td5 (2009-now)
Post #867061 13th Nov 2020 11:27am
bankz5152
I do have ABS yeah, going on an 04 110 XS.
Good info cheers Instagram @defender_ventures
Post #867063 13th Nov 2020 11:40am
90 Dreamer
not sure of the specific piston sizes on the LR's but in most cases you will find that the front calipers would add far too much effort if switched to the rear regardless of your front set-up........
Post #867065 13th Nov 2020 11:54am
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Make sure you bleed them well, and follow the bed in instructions. Took 3 goes to bleed mine of all the air, I have the rears too. Thumbs Up
Post #867322 14th Nov 2020 3:24pm
