Home > Europe > Cyprus pictures and things to see |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
The pan handles a different world for sure. Original Member Pie n Pea Club.
110 HCPU Tipper |
19th Aug 2011 9:10am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
thanks Glyn,keep um coming 2.4 90 XS
19th Aug 2011 9:15am |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
nice pics.
Pom |
19th Aug 2011 9:22am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2954 |
Im soooo GREEN you lucky sod
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Hills North of Episkopi Village
I drove North out of Episkopi towards Souni. This is a Main road that passes through a large area of land caught in bush fires. The ground was all black other than the dust tracks and weeks later you can still smell all the burnt ground. I didn't have a chance to take pictures but I will venture back that way soon. Once I was near high ground the country opened up and you can see hundreds of dirt tracks covering the hill sides. I looped around several small villages including Vouni and a beautiful village at the bottom of the valley called Kilani- stopped at a cafe and had some awesome food. Due to this being the point I saw my Vacuum pump seal had just gone, the trip was called short and I ended up taking the shortest route home. [Picture] Views of the valleys with dirt tracks- it is easy to just pick a direction and just chop and change routes on the tracks. Click image to enlarge Click image to enlarge TIP OF THE DAY: If traveling with the window open and in the 'Defender arm out window pose' be sure to apply sun cream to your left/ right arm (depending on LHD/RHD). Otherwise you get home with one normal arm, and one RED arm!! Glyn :sheep: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
19th Aug 2011 9:26am |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Stopped for a Greek Mac at that McD's near Skarinou on the A1 a couple of weeks ago, and saw a Toyota 4x4 and a van full of 'blue caps' doing the same thing. How you guys get on in full camo gear in that heat I don't know!
Pete |
24th Aug 2011 9:10am |
It is brutal.... But I have to admit that I haven't worn uniform for over 2 months (wore it about 3 times since being out here). Due to my job I am wearing t-shirt, shorts and trainers .. like a real holiday!! Have you had/ having a good trip? Glyn |
24th Aug 2011 9:16am |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2653 |
Glyn
Are you working secretly undercover for the Cypriot national tourist board or as a recruitment officer for the British army! Either way I'm sold Mark (jealous) |
24th Aug 2011 3:29pm |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
cracking pics Glyn
24th Aug 2011 7:01pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Nice pics Glyn,
Looks quite similar to the north-central part of Chile (Same climate as well)} Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
25th Aug 2011 1:41am |
Thanks Glyn, Yes, it turned into a good trip which I managed to drag out to the best part of three weeks! Spent a few days working (a bit longer than I'd expected), and then organised the family to come out. We had the best part of a week in Oroklini (just north east of Larnaka, just off the Dhekelia Road), and then drove west and spent just over a week at a place we regularly stay at in Paphos. Wasn't really bothered by the power cuts as they seemed to occour when we were out and about, and once work was over it turned into a nice relaxing family holiday. Having the family out was the main reason I didn't get in touch, as there was never really an opportunity while we were over your way. It was properly scorching and I came back to the UK looking almost black! You must have to be a bit careful with exposure now you're effectively resident. Lucky you can wear shorts and t-shirt for work, I'd struggle (and did for the first few days) having to wear anything more! Pete |
25th Aug 2011 7:35am |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 |
lovely pics glyn 2004 TD5 Defender 90 xs station wagon
28th Aug 2011 6:06pm |
I would tell you guys what I do here, but would then have to kill you
Good to hear it all went well and you made the most of the sun. Back in UK I used to put moisturiser on to stop dry skin, so here I have just swapped the moisturiser for factor 15 sun lotion. I am the same colour as the locals now, and will be learning Greek next month so will have know the lingo too......I will have to change my name to Spearos soon. There will be more updates soon as the new vaccum pump should be here tomorow, and then I just need to find a charging cable for my camera. Glyn |
30th Aug 2011 11:28am |
ARMYBOB Member Since: 16 May 2009 Location: north luffenham, rutland Posts: 81 |
hey glyn theres a nice castle at kollosi!
30th Aug 2011 5:54pm |
