Home > Tdi > New Radiator for 200tdi - part number question... |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6628 |
From a very quick look it is listed as a pre-Tdi radiator, it is full width not the 3/4 with space for the intercooler 1988 90 Td5 NAS soft top
2015 D90 XS SW |
7th Nov 2020 10:13am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2672 |
Which makes sense as for the majority ex-MOD means 2.5NA engine.
A 200Tdi radiator is BTP1823 or BTP1823S. Your local radiator place will be able to re-core your existing rad, or if buying a new one make sure you get a proper brass/copper radiator and not one of the aluminium/plastic contraptions. |
7th Nov 2020 10:28am |
Woody3 Member Since: 13 Jan 2010 Location: Derbyshire Posts: 415 |
Thanks chaps - it didn't occur to me that the pre TDI were full length.
And yes, I've read some of the horror stories regarding the aluminium/ plastic rads. I will make some enquiries regarding a re-core, but failing that, I'll keep a look out for a new copper/brass rad, using the correct part number - thank you! |
8th Nov 2020 1:32am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5216 |
My dad bought a alu unit, from the local rad place. They do a copper counter part, but that was a lot more. the only bother he has had, was the Cooler ends, but a bit of white tape on the ends sorted that out. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
21st Nov 2020 6:02pm |
