Home > Maintenance & Modifications > Mud protection options
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
Ok I’ve tried searching and can’t seem to find a thread/post I stumbled upon earlier so here’s a new thread.
Time has come to replace my mudguard brackets.Has anyone fitted Gwyn Lewis kits (the wheel arch shields) AND
Dirt D-Fenders? I like the functionality of the former and the look of the D-fender but can’t seem to find if the two are compatible? Or if it even makes sense to fit both?
Post #865567 5th Nov 2020 5:56pm
jimbo55
I have the gwyn Lewis mud shields all round on my 90 including the front mud flap kit.
The front works really well, they were fitted about 3 years ago and have kept all the mud out from being trapped against the footwell and outrigger, even after a lot of abuse off road. As for stopping mud spraying up the doors they do a great job, although that does depend on how far out your wheels sit. My tyres sit flush with the outside of the arch and mudflap and it keeps it very clean on road. I haven’t used the dirtdefenders so can’t comment on them.
The rear mud shields in front of the rear wheel arch do a good job of keeping mud out of the top of the arch but do have to clean behind it a lot more often than I thought. As for the rear cross member shields, I have only had them on a month or so now so can’t really comment on them.
Post #865578 5th Nov 2020 6:50pm
LR90XS2011
ditto
I have a 90 with the Glynn Lewis front wheel shields and the rear cross member shields, I still need to fit the ones at the front of the rear wheels,
I generally only use mine on the road and brought them to stop stone damage as much as mud DEFENDER 90 TDCI XS,
Post #865597 5th Nov 2020 8:06pm
jst
I have them both on my 130. Probably depends if you get the stepped out mudflap bracket from gwyn. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #865600 5th Nov 2020 8:08pm
Avelingporter
I have GL wheelarch sheilds all round on my 90, front and back rear and rear of front. Brilliant. I have dirt d-fenders on the rear of the front arches. Again brilliant. BUT if you want the GL front mudguard relocation Kit to push them out then the dirt D-fenders aren’t needed.
Post #865602 5th Nov 2020 8:12pm
MussEd
Thanks folks. Sounds like a combination of both might do the job....
Post #865621 5th Nov 2020 9:58pm
Ianh
I loved this idea when I saw it https://www.defender2.net/forum/topic70904.html. And likely to do it in the spring
Post #865645 6th Nov 2020 12:26am
MussEd
That does look pretty neat, sadly my hamfisted nature means I always look for a ready measured and cut solution! Thanks though...
Post #865686 6th Nov 2020 10:44am
defenderandwe
United States 1997 Defender 110 300 Tdi SW Santorini Black
I have been conflicted with purchasing the front and rear Gwen Lewis wheel whell protectors. Im glad to see many people use it here!
Post #879041 17th Jan 2021 10:29am
The Gwyn Lewis kit is excellent. I've fitted the front, front of rear wheel arch and the rear mud flap kit to mine, which protects the rear crossmember. There's a write up in my build thread here: https://www.defender2.net/forum/post727189.html#727189 Darren
Post #879047 17th Jan 2021 10:45am
MussEd
I fitted Dirt D-Defenders then the Gwyn Lewis kits. Dont mind admitting I was bricking it drilling stuff at the start but now I’ll take the Hilti to anything! The shield kits make a massive difference to crap getting into hard to reach bits underneath. Would’ve been so simple for LR to fit these from the start but I suppose that would’ve denied me the opportunity to feed my new drilling addiction!
Post #879052 17th Jan 2021 11:09am
Mo Murphy
You can make your own for the price of a square M of 3mm HDPE and a length of 20mm stainless angle (was on the corner of the bath and save when I redid the bathroom).
50 Shades of Pennine Grey
Post #879078 17th Jan 2021 2:22pm
jst
Plenty of pics of gwyns kit fitted to my 130 on my 130 thread around 7 April https://www.defender2.net/forum/topic71658-45.html Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #879081 17th Jan 2021 2:46pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
|I went down the same route after reading your thread Darren - well worth it. Rgds.
Chris
Post #879150 17th Jan 2021 7:13pm
landy andy
Post #879166 17th Jan 2021 8:09pm
