Home > Maintenance & Modifications > Footwells - Not Sure Which Way to Go - Any Suggestions |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
I would go for second option then it is done properly but as you say doing it this time of year is problematic, so maybe just treat the rust the best you can now and sort properly in the spring?
I think most of the screws are into plastic clips so might come out easier than you think. Drilling the heads off might be better than an angle grinder. |
5th Nov 2020 9:55am |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1845 |
I'm with Scotm - better to do it properly, but at this time of year maybe something quick.
One thing I would say is to try and get those screws out, rather than skimming the heads off. That will allow you to lift the floor, but then you'll also have to deal with the remnants of the plastic inserts - and those ones are stronger than you think. Maybe one of the 'mangled nut extractor' things in a small size would grip the screw head? Or a left hand drill bit followed by a stud extractor if needed? .......Or you could just grind them off too once you have the floor up. Either way, I'd suggest having a new set of those inserts to hand, and when I did mine, I used stainless screws on the replacement, with a nylon washer to separate the screw from the alu. floor. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
5th Nov 2020 10:04am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello rustyredwreck
Or Option 3 As you are where you are... remove all loose rust... paint with a good Rust Converter, if you have the same underneath then do the same, Replace Mats, wait until next Spring then Option 2... if Rust is mainly inside and minimal / not outside, find and fix leak(s) Option 4 Leave as is but repaint Red (sorry couldn't resist) Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
5th Nov 2020 11:45am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5850 |
Option 5. Buy a 2nd hand set of floor panels. Paint etc and leave to dry and then fit.? 1999 Defender TD5 110
5th Nov 2020 11:46am |
rustyredwreck Member Since: 16 Jan 2020 Location: Oxfordshire Posts: 24 |
Thanks everyone for your suggestions.
I really want to do the job just once and do it properly, so maybe there's another option - don't do anything until Spring? I'll have a think. X4SKP - you're closer to the truth than you know. Rusty Red Wreck was my first land rover - a fantastic Series III 109 CSW in Masai Red - which I absolutely loved. I read all the "buying a series III" articles I could find and, armed with a hammer (to gently test the chassis), went and inspected it, bought it and drove it 200 miles home. Love at first sight! Next day put it on a ramp and I have no idea how it happened but I missed every bad bit of chassis the day before - it was a wreck. I still miss that 109.....a Defender just isn't the same. One day I'll get another series III 109 CSW - Rusty ended up in the states i think. Thanks again all. |
5th Nov 2020 12:29pm |
