Home > Td5 > Td5 having problems getting into reverse and 1st. gear
Photographereden
Australia
Hello All, Advice needed please!!
I have just bought myself my first land rover 2003 Td5 90, with 186k kms.
I’m having problems getting into reverse and 1st. gear, gear selection to be very sticky.
Will go in gear fine when engine is off, no loud noise when clutch is suppressed, no slipping)
Has anyone had this problem before? Could it be clutch slave master? Or could it be something else?
Thanks for advance
Post #865189 3rd Nov 2020 10:56am
landy andy
Check clutch adjustment and change the box oil would be my starting choices.
Post #865203 3rd Nov 2020 12:47pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
You can try to reset the bias springs on both sides of the shifter tower. Normal wear and being out of adjustment often causes hard engagement of gears.
Good luck
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #865244 3rd Nov 2020 4:21pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Hello,
Wear in the turret can also make some gear selection imprecise and difficult to select.
Regards
Chris
Post #865246 3rd Nov 2020 4:34pm
If it's ok with the engine stopped and not with it running it will be clutch or spigot bearing.
Post #865253 3rd Nov 2020 5:17pm
4RF RDS
True, read the OP and missed that somehow Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #865271 3rd Nov 2020 7:07pm
HansT
Sweden 2004 Defender 110 Td5 SW Belize Green
I had that problem for a long time in combination with a terrible nose. Typical spgot bearing but I had the clutch, flywheel etc replaced at the same time since the mileage was 180 000 km. The noise is gone and it is easy to select gear.
//Hans
Post #865300 3rd Nov 2020 9:29pm
Lionel
Australia
Re: Td5 having problems getting into reverse and 1st. gear
Thanks for advance
Sound like the clutch is not releasing properly. There are a number of possible causes for this. I would check:
1. Fluid level in clutch master cylinder. If OK, it is still possible that there is air in the system, particularly as you are not sure of the vehicle's history. Try bleeding the clutch. If low, check the hydraulic line & both master & slave cylinders for leaks.
2. Check the pedal adjustment. There should be a small amount of play in the pedal (5mm or so). If excessive, you will need to check adjustment in the pedal box under the bonnet.
3. By your description of no noises or no slipping, it is less likely that the clutch unit itself is causing the problem.
Cheers,
Lionel
Post #865314 4th Nov 2020 12:33am
Photographereden
Australia
Thanks mate, all good now 2 mins done cheers
Post #865335 4th Nov 2020 8:37am
andylee
And the fix was ?
Out of interest what suggestion fixed this issue?
I also have a 2003 CSW with the same issue with 1st and Reverse only...
thanks
A
Post #879730 20th Jan 2021 2:00pm
Photographereden
Australia
Very easy, I just adjusted the master cylinder a little bit, now is very smooth
Post #879745 20th Jan 2021 3:39pm
The Crab Botherer
United Kingdom 2001 Defender 90 Td5 ST Nato Green
Nice result!
i had very similar issues but it turned out to be a combination of pedal height/ m/cyl adjustment and turret adjustment.
Post #879757 20th Jan 2021 4:18pm
