Home > Puma (Tdci) > Tdci double cab rear seats and station wagon |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Ash
If you can be more specific about what you are trying to see about the DC rear seats I will try and sort some photos for you. Bob |
28th Aug 2011 8:49pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
i also could get some pis if you can explain a little more, my understanding was that the seats are the same, though the double cab has them sitting a little forward and also bolted in possition, saying that 2 mins with a 10mm spanner and they fold like usual.
HTH mark |
28th Aug 2011 10:07pm |
Knot Yet Member Since: 01 Mar 2010 Location: West Sussex Posts: 197 |
Why are they bolted into position, they are very upright in the DC
Sorry probably a dumb question!! J Defender 110 Puma Utility XS |
29th Aug 2011 5:16am |
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 286 |
Hi thanks for the quick replys, I have just built a Tdci double cab,and have a problem with the back seats.
The back seats I have are out of a station wagon. I have tried the middle row seats in only to find the backs of the rear seats catch on the rear window frame Like mentioned they must sit further forward on the base some how to allow the says to lock in the upright position. Thanks again ash |
29th Aug 2011 7:14am |
bank holiday slow start here, i'll get one of the kids on to taking some pics of the brackets later and will post,
it does seem that the brackets are there because the seats can't travel all the way back, saying that my son 5'11" just about manages and i have my seat all the way back. pics later mark |
29th Aug 2011 8:38am |
Hi mark thanks
29th Aug 2011 9:46am |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 |
Seats definitely more up right in a DC.
29th Aug 2011 9:47am |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 |
Took seats out back of my DC and replaced with Exmoor trim new seats & frames - now have tip forward highback seats meaning can get access to space behind & underneath for storage, PLUS any back seat passengers do not have the rear window as a headrest!
EDIT-Just to add, mine are held locked in place with a key latch lock, 1 lock on each of the outer seats. Rock solid, but quick to release if required.- 2001 TD5 110 DCPU in Bonatti Grey Last edited by daviec1 on 29th Aug 2011 2:49pm. Edited 1 time in total |
29th Aug 2011 10:35am |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
...the problem is to bolt them again ! Manage to bolt them back twice ... the third time I needed to bolt them back, gave up ... it's fixed with a plastic tie wrap... If no one posts a pic of the seats till this afternoon, I can take a set and post when I get home Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
29th Aug 2011 12:49pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17338 |
I have an '07 Puma DC. My rear seats are standard and I have unbolted them from the top fixing brackets.
They tilt and lock on the tilting catches in exactly the same way as on an SW and I have never understood why they were locked in position to begin with. |
30th Aug 2011 10:47am |
Got a rough idea but pics still needed
Thanks |
30th Aug 2011 6:27pm |
Here are a couple ...
If you want a more specific one let me know Click image to enlarge Click image to enlarge Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
1st Sep 2011 7:47am |
Hi lrmaniac, thanks for the photos
Would it be possible to take some pictures of the base of the seats,and one from the outside looking in(to see what upright position there in) Many many thanks Ash |
1st Sep 2011 9:09am |
The base of the seats or the base where they sit (cab floor)? I still have this one Click image to enlarge Can take one from the outside, but if you want to see the seat base I'll have to unbolt them, and it takes time ... And next two weeks wont arrive home in time and with enough daylight to do that ... Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
1st Sep 2011 9:32am |
