![]() | Home > Maintenance & Modifications > Rear window seals & filler strips |
If you mean the little ones on the back the beads should be on the inside, but it really makes no difference for security as the windows can be removed in seconds either way. Ray
izack98 Member Since: 25 Sep 2016 Location: Vancouver Posts: 26 ![]() ![]() ![]() |
Just reviving this thread. Does anyone have any tips on reinserting the rubber 'lock strips' into the channel once the 1/4 glass has been reinstalled with new rubber? I got the new rubber in, fiddled with the glass and finally got that in. I am now wanting to insert the lock strips into the channel on the inside. It's pretty tight.
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
You need a Claytonrite tool
Somethign similar to this https://www.ebay.co.uk/i/163428377027?chn=...TvEALw_wcB |
Ah yes. Thanks Landyman! I have seen those.
I will pick one up. A screwdriver and a bunch of cursing just wasn't working. |
