Home > Puma (Tdci) > What springs
110 Iain
United Kingdom 2008 Defender 110 Puma 2.4 USW Chawton White
What springs
Running an 08 puma 110 hardtop need to change rear springs can't tell what's currently fitted as so corroded but rear is very harsh most spring see on line are all heavy duty rarely load it up so wanted to fit something to take the crashing down a bit will td5 progressive work anybody
out there changed hard top to something softer any advice appreciated Iain Endeavour To Persevere
Post #864313 29th Oct 2020 7:28pm
Grenadier
I wonder if you have stock HD springs? I think general consensus is to use the 110 SW spring, (someone on here will know the part number), if you're after OE. Or use the Alive springs made by Eibach if you want something a little better. Not sure about how much difference there is between Td5 springs and TDCi apart from the latter no longer being 'handed'. They're both very cheap, so not the best, but there's a noticeable gain with the Alive set up. I suppose ultimate usage will impact your decision... Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #864333 29th Oct 2020 9:15pm
Bluest
Old Man Emu do a softer spring but it comes with a small lift which may not suit. 2007 110 TDCi Station Wagon XS
Post #864335 29th Oct 2020 9:45pm
On my USW, I swapped the standard purple/brown springs for the dual rate white/green/green station wagon version, which are much more pliant when lightly loaded. The different weight of a hardtop means you wouldn't get exactly the same result but you would still see a benefit for not a lot of money. Darren
Post #864338 29th Oct 2020 10:05pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
The springs do help but for maximum effect you'll also need to change the shocks for Koni Raids or similar adjustables Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #864353 30th Oct 2020 1:04am
