![]() | Home > General & Technical (L663) > Lane Assist Help |
doctorusa Member Since: 21 Jul 2020 Location: usa Posts: 4 ![]() ![]() |
is it possible to get just a audible warning for the lane assist without it being active and helping the car back into the lane- been playing with settings and can't get it. Thanks
eelpout Member Since: 04 Jun 2020 Location: California Posts: 9 ![]() ![]() |
I have a MY17 Discovery, wonder if they changed it (mine has some OEM Bosch unit I believe), because on mine you can change from steering control to a simple vibration of the wheel instead. The US Defender manual is here and it doesn't mention anything about being able to change it. Hmmm. |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
You can disable the system so that it only switches on when you want it. It took a bit of fiddling in the settings but mine is off and doesn’t need turning off with every restart and I can enable it immediately with the steering wheel controller. It won’t vibrate the wheel though when it’s off.
I wanted it off because I have loads of very narrow but not single track roads where I live and often have to straddle the central white lines or drive with the oases gear side almost in the ditch, with the system operational it kept trying to drive me into the ditch automatically Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
I'm hoping they updated the lane keep system with the intro of the new Defender, because the one I have is a bit unpredictable.
