Home > Td5 > Doesn't ignite properly.
Page 2 of 4 <1234>
roel
It is not a stupid question but one that is a little more difficult to answer.
You say it revs fine, so no strange sounds. So I expect it is something to do with electronics. At least not mechanical inside the engine. Based on this I think I would have no problems driving that short section.
Is your oil level still OK not a little higher then expected? Roel
2003 90 Td5 (2009-now)
Post #863993 28th Oct 2020 9:24am
The wildest man in town
Sweden 1999 Defender 110 Td5 PU Coniston Green
The oil is on the high side. Aprox 0,5-1cm above the top marker on the stick.
What does that mean?
Last edited by The wildest man in town on 28th Oct 2020 5:19pm. Edited 1 time in total
Post #864046 28th Oct 2020 4:06pm
dorsetsmith
may be Injector Seals fuel getting in lube oil
Post #864053 28th Oct 2020 4:28pm
roel
http://www.youtube.com/watch?v=8feJpEuzZEM
Not that difficult to do yourself. The video shows special tools to get the injector out but that is not needed.
I did mine recently
https://www.defender2.net/forum/topic74330.html Roel
Post #864081 28th Oct 2020 6:35pm
Thanks! I ordered new seals + o-rings. Fingers crossed! 😬
Post #864151 29th Oct 2020 7:30am
roel
I am sure this is the problem. After you have to change the oil too. Roel
Post #864300 29th Oct 2020 6:41pm
Found a new possible issue.
There’s a sound, like air is leaking, from the fuel regulator when the fuel pump is running. Should is do that?
Post #864554 31st Oct 2020 10:37am
dorsetsmith
no
also have good look at the fuel head
Post #864559 31st Oct 2020 10:44am
roel
If you hear air but it doesn't leak diesel, can it not be air that is purged back to the tank?
It should not leak air as there should not be air. If it is failing it normally leaks diesel.
I would first worry about the injector seals and then have a look if the regulator still makes noises. But without leaks don't worry. Roel
Post #864822 1st Nov 2020 6:33pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Are you sure you hear air? With in tank fuel pump working, the fuel pressure regulator is holding constant fuel pressure in engine and what is over, it is releasing back to tank. This is made by a regulating element in the fuel pressure regulator, with some small "hole" in it. And fuel flowing through this "hole" makes noise like escaping pressured air.
Air in fuel makes different noise - bubbling. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #865158 3rd Nov 2020 8:09am
Thanks for all the input!!
I decided to drive her to a garage where I can change the washers and orings.
Turns out, when the engine temperature goes up, the problem disappears.
I’m still going to change the washers, but this was a relief.
Thanks for all help. I guys rock!
Post #865591 5th Nov 2020 6:40pm
Turned the engine about one revolution counter clockwise while i was tightening the first screw on the injector. I wasn't thinking it might hurt the engine, but now it's difficult to rotate the engine clockwise. It turns, but rotates back to same position.
Did I hurt the engine turning it counter clockwise?
Post #866163 8th Nov 2020 8:56pm
Ianh
I expect that the valves are closed on the cylinder and now you have sealed the injector you are compressing the air in the bore when you try to rotate the crank, hence it bounces back when you let go the spanner. I can’t see why this would be an issue as you have not touched the timing chains and sprockets.
Post #866184 8th Nov 2020 10:08pm
Ianh
Thinking a little more on this. There is a possibility that the timing chain could have jumped a tooth etc by rotating counter clockwise, I expect the experts will be able to advise.
I suppose you could loosen off the injector so the seal is Brocken then manually rotate clockwise to see if all is still rotating ok. But not sure if it’s ok to loosen then re tightening new injector seals. Again those more qualified will be able to advise.
Post #866192 8th Nov 2020 11:59pm
dorsetsmith
http://www.discovery2.co.uk/Injector%20Seals.html
it bounces back when you let go the spanner. this will be compression as you bring the piston up to TDC
if you think chain has jumped line up the timing indicator's between cam Shraft and the crank
https://forums.lr4x4.com/topic/101695-td5-...rankshaft/
Post #866225 9th Nov 2020 8:42am
Page 2 of 4 <1234>
