Home > Wheels & Tyres > Continued Tyre Faff (noob questions)
kenzle8a
After years of picking R compounds for my Cooper S I'm learning as much as I can about the Defender.
My only exp was our old farm truck on the OE Michalins about 15 years ago but it was only pottering between fields.
Now I have a 110 TD5 that needs to work towing (90% Road) and maybe 10% in muddy fields. Its a work truck and isn't used for greenlanes or anything like that, it goes between and through fields on the farm, mostly on B roads all year.
They need to work on road and in the wet / ice and snow most of all, I've discounted the KO2 after reading various reports.
I've been looking at the following Tyres:
https://4x4tyres.co.uk/product/265-75-16-c...3-4s-116t/
https://www.costco.co.uk/Tyres-Automotive/...e/p/539093
Post #863889 27th Oct 2020 7:56pm
jst
Not sure why the ko2 were discounted, ideal in your situation I would of thought if not maybe a bot too aggressive for your 90/10 usage.
I would also consider continental contact and the grabber at3. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #863895 27th Oct 2020 8:34pm
kenzle8a
I've read a lot on here about them (KO2) being a bit pants in the wet / ice. Happy to add them back on the list if folk think they are Scottish enough.
Buying Defender tyres is a whole new minefield for me. The Cooper S is pretty simple. AO52 R comps in the summer and Pilot Sport 3's for the winter.
Post #863896 27th Oct 2020 8:38pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
I have never had problems with the KO2’s in the wet but have heard that the mud terrains are not that good in the wet.
Post #863900 27th Oct 2020 8:48pm
kenzle8a
That I've found out Shocked it currently has BFG Muds on it (came with it) not utterly awful but since one doesn't go mud plugging they aren't needed for what I do.
Post #863902 27th Oct 2020 8:50pm
Retroanaconda
I’ve done close to 150k on my last two sets of the BFG ATs with no problems. They’ll let go in the wet if you push hard enough but no worse than any other AT in my experience. Drive it like a Land Rover and no problem.
I’ve also never found any difference in fuel economy or noise between road patterns and the BFGs, as such I can’t see any reason not to run them as their grip off road is obviously far better. They don’t cope well with deep mud like a MT does, but I generally do my best to avoid that sort of terrain.
Post #863908 27th Oct 2020 9:14pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I am one of those who doesn't like the KO2 for cold wet braking. I am thinking of Cooper's or Falken when I replace.
Post #863918 27th Oct 2020 9:36pm
Zed
I'm not impressed with KO2's either. Swapping for Pirelli Scorpion AT plus next time around. WARNING.
Post #863924 27th Oct 2020 10:02pm
I can recommend General Grabber AT3. Very civilised on the road and winter rated so good for snow/ice/wet. Darren
Post #863939 27th Oct 2020 10:56pm
bear100
I have had KO2’s for a few years now and never had a problem with them in the wet or the snow, I personally think they are great all rounder tyres, recently done a 4K mile trip around the alps and they performed really well on and off the road, wear is fantastic they are easily going to hit 40-50k 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #863943 27th Oct 2020 11:14pm
JOW240725
I haven't had any issues with KO2's. I think maybe batches vary. James
Instagram @suffolk_rovers
Post #863949 27th Oct 2020 11:29pm
SWMBO has KO2s on her L200 and they are completely satisfactory in wet, dry, cold and heat as long as you don't drive like an idiot. I've driven half a million miles on KM2 and KM3 on my Disco and Defender and they are also excellent in wet, dry, cold and heat unless you drive like a fool, but they can be tricky on compacted snow on tarmac.
I imagine that either of the tyres in the links will be grippier on tarmac than KOs or KMs but will be almost useless in a muddy field unless the field is frozen.
Post #863950 27th Oct 2020 11:31pm
Ianh
Another one to consider are Goodyear wrangler duratrac 265/75R16. Worth reading reviews but my personal experience is they are good on the dry road, in the wet and in the snow. I’ve not used in the thick mud but reviewers say they perform well. Not as good in the mud as a dedicated mud tyre but well enough considering their good performance in other areas.
They don’t seem to get mentioned much on here as they are not available as a 255/85r16 , which is a size I would go for if available, but the 265/75r16 have performed very well over the last 5.5 years.
You get many different and varied tyre reviews when you search on any particular tyre. However I think this one is accurate given my experience of dry, wet and snow use on the road, so the mud use will hopefully be as accurate. https://canadiangearhead.com/best-offroad-tire-for-winter/
The author reviews his 245s and 285s but his general view is consistent for both, and the 265s sit in the middle of that range so I think the review may be helpful.
Post #863965 28th Oct 2020 2:56am
kenzle8a
Food for thought, I’ve looked but can’t find the Duratracs in 16 anywhere. Looks like the ko2 is worth a try. I don’t drive like a loon, i have other cars for enjoying track days etc.
Post #863987 28th Oct 2020 9:42am
Chicken Drumstick
Re: Continued Tyre Faff (noob questions)
Either of the tyres you list will likely work fine. They are more road biased however. If you think you will end up in a muddy or wet grassy field however, something more aggressive will work loads better. So it's a trade off.
The other option, if you really need the best 'on road' performance for snow and ice. Then a more dedicated winter tyre might do the trick. But may have accelerated wear in warmer dryer conditions.
KO2's would probably work well. I think most of the wet road complaints stem from the older variants of the tyre. Not so much at the currently one. The older ones also had a rep for going hard and never wearing down, but once hard they really were rubbish in the wet.
Post #864002 28th Oct 2020 11:28am
