Home > In Car Electronics > Indicator Issues on driver's side |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
Left and right circuits are independent, and have their own fuse. Maybe can check fuses first, under steering wheel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
26th Oct 2020 7:14am |
nick.bw Member Since: 26 Oct 2020 Location: Essex Posts: 72 |
Oh. Thanks. Do you.know which fuse to check? Thanks. Nick.
26th Oct 2020 8:07am |
two fuse one for Indicator and one for hazard fuse 21-31 check lamp holders for corrosion and failing do to bad contact
26th Oct 2020 9:38am |
Thanks all.
Side, Front and Rear indicators have been off, cleaned and put back on. If i still have the issue i will swap light from right to left. Seeing as i dont have a fuse per side, it can not really be the fuses causing me issues. Thanks Nick |
26th Oct 2020 10:51am |
If its all that side that your having problem with have a look at steering wheel switch also do you same problem with hazard
26th Oct 2020 11:23am |
yep, had the issue with hazards on.
Because its intermittent, its not an issue at the moment while its on the drive. thanks DoresetSmith! |
26th Oct 2020 11:39am |
I check manual, indeed 2 fuses supply the Switch-Hazard warning S121. Circuits are of course separate after this switch.
Could be the hazard switch. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
26th Oct 2020 12:55pm |
If you have the towing electrics. Check that the back of the socket is clean and dry, you will have to remove the socket and pull the boot back, its normal to find it full of damp silt. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
26th Oct 2020 3:09pm |
