Home > Puma (Tdci) > Ouch – Clutch and More |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 |
Dang. I feel your pain.
23rd Oct 2020 11:14am |
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 187 |
hi just had my gearbox replaced @96k miles no change out of £3k
23rd Oct 2020 11:54am |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 671 |
Yep that is what I am expecting!
23rd Oct 2020 12:36pm |
gearbox alone £2196
23rd Oct 2020 2:21pm |
That must be straight from land rover? Think mine is £1100 plus vat.
23rd Oct 2020 6:06pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3453 |
Cannot replace the input shaft? Or cheaper still, skim and sleeve it? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
23rd Oct 2020 6:41pm |
Apparently replacing requires gearbox dismantling and likely to find other stuff at same time at this mileage so may as well swap for fully refurbished unit.
Sleeving option wasn't mentioned. Would shaft not need to come out to machine? |
23rd Oct 2020 6:59pm |
Indeed, to replace the input gear, the gearbox has to come apart. Likewise if you want to machine it down to sleeve it. The plus side if you have a box with known history.
Other option, but I do not know if it is possible - remove the high spots from the input shaft, and sleeve it oversize. But then you have to do without the bearing and have a custom made spigot bush. I know the spigot bush worked well on the old diesels. No idea why Ford went for bearing vs bush. Perhaps this is not economically viable if you have to pay a garage to do all the work. All my suggestions are based on what I would try to do, but I do not count the hours while my hands are black and greasy 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
24th Oct 2020 5:50am |
