Home > Puma (Tdci) > p1010 help |
mass air flow sensor is outside of the manufacturer's specified range.
17th Oct 2020 1:28pm |
ribdiver Member Since: 28 May 2015 Location: lancashire Posts: 4 |
replaced the mass air filter already
18th Oct 2020 11:56am |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 888 |
Replaced Filter or Sensor?
18th Oct 2020 12:13pm |
Changed that when we replaced the egr valve, absolutely stumped now
18th Oct 2020 7:44pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1788 |
Loom failed over engine block, or rubbed through near rear corner lifting eye? (if its there on a 2,2?)
19th Oct 2020 7:43pm |
Finally sorted. Out mass air flow code fault.
One on the simplest and overlooked items on the engine. The poor quality. Jubilee clips holding the pipes from the engine to the intercooler had stripper the threads and was allowing a small amount of air vacuum into the system which was triggering the sensor to trip in. Replaced all jubilee clips on. The engine with heavy duty ones and problem now. Solved |
3rd Oct 2021 4:48pm |
