![]() | Home > My Defender > hanks Double Cab |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2317 ![]() ![]() ![]() |
Having run the Provent for a few weeks I was not happy with the quantity of oil the engine was putting out via the breather due to excess crankcase pressure so decided to revisit the injector seal washers (AGAIN
![]() The only thing I had missed previously (because I didn't have the tool) was cleaning up the injector seats so I got myself a seat cutter (15mm flat for those wondering) and set to it. The injectors were heavily carbon'd up so there had clearly been blow by and inspecting each injector hole with a borescope I could see a fair bit of carbon buildup around the injector seat where the copper washer seals. I cleaned up the four seats with the cutter being careful to remove only the carbon and no aluminium head material. I also cleaned up the bores to avoids any bits getting knocked down onto the seat. Inspecting with the borescope you can see the seats ended up back to bare metal. Also cleaned out the rocker cover breather system whilst it was apart. Cleared all the gunk and carbon out of the internal breather passage and the diaphragm etc. Surprising how caked this was! Obviously cleaned the injectors right up too. Reassembled with new OE copper washers, new clamp bolts to 6Nm+180, new return seal o-rings and a new rocker cover gasket. The crankcase pressure seems to have reduced so will keep an eye on how much oil the Provent catches over time. The injector ticking noise has stopped so definite improvement and the vehicle feels as though it's driving better... But this could be psychological ![]() I will remove the injector cover after a few heat/cool cycles to check that the injector clamp bolts are still tight as I wonder whether heating/expansion and cooling/contraction of the components may leave these out of spec causing the washers not to seal. Don't know. Fingers crossed this time gets it! Some photos... State of the injectors ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Injector seats (photos taken by my glamorous assistant) ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Injector seats after cleaning ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge > 110 XS Double Cab Last edited by hank on 17th Sep 2020 11:09am. Edited 1 time in total |
The cutter has a pilot rod that goes down the hole both to plug it and maintain concentricity. The crud sticks in the teeth of the cutter and comes out with it. I also blew each hole out with an airline and a bung in place
![]() Click image to enlarge > 110 XS Double Cab Last edited by hank on 21st May 2021 2:36pm. Edited 1 time in total |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17614 ![]() ![]() ![]() |
Thank you, so obvious once you know!
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
Sorry to jump back a bit but where did you get your 'side tube seal' from?
Looks to really tidy up the bottom of the door and may help seal the bottom of my doors in the corners ![]() Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
I got it on ebay. 3m will do both sides
![]() https://www.ebay.co.uk/itm/324138668389 > 110 XS Double Cab |
Thank you!
![]() ![]() Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
Do you know if thats sold separately? My car has the sliders but they never bothered to fit the tube and I can only find the OE foam one when i've looked. |
Yeah I got mine from ebay. 3m will do both sides :Thumbs Up:
Cheers Hank
![]() Click image to enlarge Classic Landrover panel alignment in that photo, mine is just the same! ![]() |
If every panel is out it sort of has it's own equilibrium.
Yeah, doors could do with some adjustment on the hinges! > 110 XS Double Cab
Bit of a follow up on this... Since sorting the injector seals once and for all the crankcase breather is passing no oil and as a result the provent is empty! Result ![]() |
