Home > Off Topic > Which garage lights to install? |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2641 |
I bought some LED battens from Screwfix for mine, think they were LAP branded. Nice and bright and turn on instantly unlike old fluorescent tubes. Cheap enough too, and rated waterproof.
12th Oct 2020 5:36pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
I just changed my tubes for LED ones and kept existing fittings. Think new starters came with the led tubes.
12th Oct 2020 5:40pm |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 316 |
Do you know what the lumens and colour temperature were? There seems to be quite a range from Screwfix.
12th Oct 2020 5:42pm |
Bev Member Since: 03 Apr 2013 Location: Perthshire Posts: 267 |
I bought 4 of the LAP LED lights from Screwfix, I think you got a bit of discount for buying the fourth one. The lights are mounted one in each quadrant of the garage and give of a balanced light across the entire floor
https://www.screwfix.com/p/lap-single-5ft-...00lm/1079v I reckon you could easily mount them on the side walls of the garage for a similar light spread..... I have two mounted that way on another garage that’s smaller and somewhat older/ darker than the house garage and they work just fine that way. I think you can run up to 5 or so in series making the wiring simple... 2002 Td5 | 90 County Station Wagon | Oslo Blue 2006 Td5 | 90 County Station Wagon | Tonga Green (Gone ) 2002 Td5 | 90 County Station Wagon | Zambezi Silver (Gone) Last edited by Bev on 12th Oct 2020 6:28pm. Edited 1 time in total |
12th Oct 2020 6:21pm |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3497 |
Light brightness will be recorded as the K figure. 4000k would be a normal standard light temperature for say an office. Higher temperatures (4500k, 5000k) the cooler colour becomes or more blue. The lower the number the warmer the white or more orange the light.
4000k or 5000k will be fine for a garage workshop. Fluorescent tubes had similar ratings except domestically we used to call them cool white or daylight tubes. Hope that helps |
12th Oct 2020 6:26pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
Me too. I got mine from Toolstation and all I had to do was fit the starters they came with. They come on instantly and seem to last well. |
12th Oct 2020 6:28pm |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 405 |
Lumens is a rating of how much or bright the light gives off.
Colour temp is rated that the higher the number, say 6000k the more blue white the light. Lower number, 3000k for instance, the warmer the light. 2700-3000 being similar to an incandescent traditional filament light bulb. Or the old style Defender 7” headlights. 6000k is more like the bright blue white fridge lights. Do not confuse lumens with temp. Just because a light is warmer does not mean that it is giving off less light. I would look for the leds for your garage to be 4000k, easy on the eye and not like opening a fridge. I’ve just fitted the same a month ago and really pleased. |
12th Oct 2020 6:31pm |
Mine were the same as the ones Bev posted a link to. They can link up to 8 in a row I think. |
12th Oct 2020 6:34pm |
Also worth noting that the lights wattage is not directly proportional to the light output. This is why we now use lumens as an output. One 40 watt led strip light may have a higher light output than another whereas a 60 watt light bulb was more or less the same whichever bulb you bought.
Mostly, the more money you pay for your lighting, the more efficient the LED lighting will be. This is the lumens per watts. Screwfix LED lights will be at the value end of the market and perhaps not as efficient as more expensive ones. Saying that, I have Screwfix lights at home. Some LED strip lighting will not be much more efficient than a fluorescent (although they should be more efficient than a T12 8ft Fluorescent!). Nothing wrong with Screwfix |
12th Oct 2020 6:35pm |
If you have existing 8ft Tubes, you may struggle to find replacement LED Tubes to retrofit in your existing light fittings. Google 8ft LED Tubes I found these: https://ledsave.co.uk/2400mm-8ft-t8-led-tube.html Never used the company so can’t vouch for them. |
12th Oct 2020 6:53pm |
Thanks for all your suggestions. Replacing the 8ft tubes sounds like a good idea, so I won't have to re-wire etc.
I looked at Toolstation, and they don't seem to have the 8ft LED tubes. I found the below, so would these work? https://lowenergysupermarket.com/product/l...gLcrvD_BwE Thanks John |
12th Oct 2020 7:03pm |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 809 |
I’ve just fitted LAP 4ft 22W 2100lm from Screwfix in my Garage, £26ish each - very bright. 2 is plenty for an 8x5m space. They daisy-chain together which is handy.
12th Oct 2020 7:05pm |
Yes John. Just what you need. The only caveat is do your fluorescents have starter switches in them? If they do, easy fix. Take the fluorescent starter out, fit the LED fake starter in. If they don’t, you will need to do a bit of internal rewiring within the fluorescent. If this is the case let me know and I will explain what you need to do |
12th Oct 2020 7:28pm |
If you mean the little cylinder starter that plugs in the side with 2 pins, then yes.
12th Oct 2020 7:34pm |
