![]() | Home > Wheels & Tyres > Tyre valve question - Ex-WMIK Blindos |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
One for the tyre & wheel experts out there - I recently bought a set of ex-WMIK Blindo alloy wheels, which were fitted at some point in their lives with a run-flat device. I'm having them blasted and painted and have removed the valves, a design which I have never seen before (only changed motorcycle tyres before).
![]() Click image to enlarge I guess my questions are whether there is any advantage or disadvantage to replacing them with the same again and also can anyone confirm that these are simply bolt-in Schrader valves and why they were used in this application? Many Thanks! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17717 ![]() ![]() ![]() |
Unless your wheels have been modified in some way to accommodate the run-flat and those valves, there is no reason not to use standard valve stems. I run normal stems in my tubeless Blindos.
I can't see any modifications to the wheels due to the run flat inserts - I'm wondering if these were just "belt & braces". I didn't think they were strictly necessary but thanks for confirming.
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 338 ![]() ![]() ![]() |
I had a trailer with these 2 piece type valves. It, I believe, was for running high loads and very high pressures.
A quick google shows these: ![]() Click image to enlarge |
I had some of these on some wheels I bought that had been used in a single make race series. I understood that they were "better" than push fit just because they could could not be removed/knocked out so easily.
