![]() | Home > Td5 > How many wires go into a rear door ? |
Do you have a high level brake light? If so and with no central locking, it should be five as follows:
Heated screen - white/black Brake light - green/purple Motor switched earth - black/green Motor ignition live - white/green Earth - black Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5262 ![]() ![]() |
You can just buy a plug in play loom for it
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
Has it got the one piece rear door/square buttons around the radio/round fog+ reverse?
If so the above is correct - though if you have central locking there are an extra pair. Pre 2002 model year (older style door/dash) wiring as follows: Heated window 12V ignition Wiper motor Park switch output Ground Brake light (Maybe) ![]() ![]() |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
Really ? I did have a looky around for a ready to go loom but couldn’t see one meself ? Mines a 51 plate vehicle with the normal radio / at an angle nestled in the older style dash And yes it has a high level brake light , |
