Home > General & Technical (L663) > Air Suspensions or Coils on the 2021 D90? |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
I’ve now owned 6 air suspended Land Rover cars since 2002 and I don’t recall ever having had a problem with it, all have been used offroad. I’m not saying it’s immune from faults as I know people who have had sensor problems or early Full Fats, Discoveries and Sports that had compressor problems - usually a blocked filter but LR changed manufacturer of compressors in the early days after a spate of problems. I would say that you are more likely to have electrinics issues elsewhere in the car than with the air springs.
I don’t recall anyone being left stranded by a suspension fault, the car has always been drivable with care. A neighbour bought a 97,000 miles 2006 Range Rover last November, the compressor had recently been replaced and new pipes fitted as a precaution as we salt roads here in winter and corrosion of pipes on a car that age is likely, so far he’s had no problems with anything but the previous owner maintained the car at a main dealership regardless of cost. Land Rover have learned a few things with their systems over the years like siting the compressor inside the car so filters don’t draw in dirt/dust. I have my own routine for raising or lowering the car on air springs in that if I can avoid it I don’t raise or lower the car when it is standing still held on the brakes to reduce stress on components, especially going from offroad height to access height or the other way. It’s not strictly necessary but even in Defender I can hear the odd quiet creek or groan from the suspension if I forget. Although New Defender doesn’t have the Dynamic mode in the Terrain Response menu that some of the Range Rover models have the Comfort mode program incorporates some of the aspects of the Dynamic setting. Also New Defender’s air springs are a new design - they are now twin chambers in each doughnut, most times it operates with one chamber inflated and the second chamber is used when the surface gets very rough to stiffen up the suspension as required. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
10th Oct 2020 8:02am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 |
Personally, I'll take air suspension over coils any day - the ride is so much more comfortable and the technology has come a long way with reliability
In fact, before C19 I was debating converting my Puma to air suspension... -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
10th Oct 2020 8:29am |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 431 |
Welcome dbit,
I've spent a lot of time configuring my P90s First, no 400 engine, to heavy, complex, no 18" rims available. The P300 is adequate. ( tuningbox will add +15%) Airsuspension Yes, for comfort and groundclearance. And all the Electronic goodies.TR2 ( I also believe in a better resale value) Electronic diff, Yes Color is very personal.. I like Solid paint, unfortunately you can choose every solid color as long It's white. See my specs in previous post. Who ordered one? |
10th Oct 2020 8:30am |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3406 |
If you’re doing off roading then yeah take the air.
On my one though, I won’t be wasting the £1600 for it. |
10th Oct 2020 9:03am |
If I were to get a 90, this is my build: https://build.landrover/F7598997
but still no availability of the new diesel engines in ZA -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
10th Oct 2020 10:07am |
dbit Member Since: 10 Oct 2020 Location: Colorado Posts: 13 |
Thanks for that comprehensive reply, Tim -- it's a big relief knowing that the vehicle's still drivable even when certain air suspension faults occur.
Defendit, choosing between the P300 and the P400 was a tough one. I like that I can fit smaller wheels on the P300 (the 18" dark gray set look sick), that the powertrain has a much simpler design, and that I can spec that awesome white roof on 90s w/ the P300 here in the states. Unfortunately I found that while the P300 is indeed perfectly adequate as many claim, acceleration from being still felt too slow when in city and suburban areas unless I was willing to rev the engine up. To me, being able to smoothly take off with the P400 and the ability to pick up speed without revving up too high made it the better choice for my use. I did have to go with the x-dynamic trim in order to get that P400 not the biggest fan of the gloss black trim pieces and having to go with 20" wheels. Not much changed between my builds though, still going with Tasman blue + the pano roof, and with a host of electronic + mechanical goodies. I snapped a picture of a P300 with the dark gray 18s while visiting the dealership earlier: Click image to enlarge |
10th Oct 2020 4:09pm |
If take off in the P300 isn’t enough you can move the selector to the left and into Sport mode then manually shift of let it go to the Rev limiter and shift up automatically. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
10th Oct 2020 4:17pm |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 509 |
i loved the air suspension on my disco 2 and plan on putting it into my defender 90 rebuild. would pick it any day over coils
11th Oct 2020 9:29am |
