![]() | Home > Technical > Defender Cluster Needle Motor Repair or replacement |
Bucko Member Since: 21 Nov 2016 Location: West Yorkshire Posts: 43 ![]() ![]() ![]() |
Hi Rugbyball,
Can I ask how you got on with your instrument cluster repair? Or if anyone else has had to have the motors replaced on the instrument cluster? I have exactly the same issue. After removing the needles to change the fascia I suspect I have damaged the motors for the speedo and the fuel gauge. Although they do still operate, they are erratic in how the needle sweeps. I have had one cluster repair specialist state that he is unable to repair as he cant source the motors, not doing to well at finding anyone else to put my trust in either. Cheers |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6661 ![]() ![]() ![]() |
I’ve had a customer do this and I recommended to buy the cheapest D3/RRS/Freelander 2 pack and salvage the motors from it to repair the expensive Defender pack. Worked a treat!
PS If it’s something you want doing (rather than DIY) I’d be happy to help.
Thanks for your advice Martin, that sounds like the way forward. I have pm’d you
Rugbyball Member Since: 04 Nov 2014 Location: Edinburgh Posts: 81 ![]() ![]() ![]() |
Hi Bucko
Just picked this up. I got in contact with several folks who said they could repair or send me a replacement motor. I only had one that didnt work after I changed the dial cad....the petrol gauge. When I shared the serial number for the instrument cluster it was either a case of those part not bing available or No one would repair or it was going to cost me my first born. I also looked into buying a Second hand donor cluster myself and thought I might swap out the motor but that was quite costly and not sure I knew whether I could do it or would make thing worse! I eventually found a guy in Essex off ebay who Could repair/replace. It required sending him the entire cluster which was a bit nerve racking, but he did fix it and everything was fine. Installed it back in and worked ever since. Contact is S u p p o r t @ F i e s t a - T e c h . C o . U K or check on ebay. ![]() 1998 50th Anniversary V8 1989 90 CSW Many Discoveries... |
Thanks for the info, it looks like the cheaper and more readily available D3/RRS/Freelander2 clusters are the solution for the donor motors.
I think I’ll be entrusting Martin’s help rather risking more damage with my heavy handed ness at removing the needles |
