Home > Maintenance & Modifications > Replacement webasto dosing pump
Matt110
I bought a thermotop C second hand from eBay earlier in the year as a full kit, was originally a Rover 75 unit I think. Works ok, I'm stripping and rebuilding before fitting. But the dosing pump is a tad beaten up and has been sprayed black in a bit of a heath Robinson fashion before my ownership...
Anyone replaced theirs with one of these generic ones from eBay and similar?
https://www.ebay.co.uk/itm/313053072965
Same external shape and size, appears same voltage, not sure on the dosing rate.
Webasto spare officially seems to be £300.
That's 3 X more than I paid for my entire setup lol.
Trouble is.... I'd rather not set fire to my vehicle. Mind you the whole things second hand and being rebuilt with new gaskets etc, rather than brand new. Must stop attempting to buy champagne with beer money!
Post #859949 5th Oct 2020 4:50pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Make sure the dosing is the same as the pump is specced to the unit, if the dosing is too great you will have plumes of white unburnt diesel in the air.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #860052 6th Oct 2020 11:27am
Matt110
Thanks, good thought, i'm fairly convinced the rather knackered old unit that came with my heater is also a Chinese copy dosing pump, and they all appear the same, but your point still stands - i'll pull the webasto tech brochure and check the dosing rate. Thumbs Up Thumbs Up
It was as much the quality of the Chinese units and whether anyone had had any issues really.
Post #860060 6th Oct 2020 12:06pm
jst
As above, any pump that delivers the right flow of fuel against time will do it Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #860134 6th Oct 2020 7:21pm
Matt110
Thanks guys. Thumbs Up
I can't pay £300 for a webasto one...
I'm after any experiences anyone has with Chinese copy parts.
Flow rate aside.
Or a way to renew it without spending that outlay. I don't trust the one I've got... But also have no experience of the Chinese copy parts from amazon\ebay.
I mean..... Look at the thing lol Rolling with laughter
It's actually got 2 dents in it. Curiously it works just fine! But over time? Don't trust it.
Post #860135 6th Oct 2020 7:30pm
dorsetsmith
If your heater from rover 75 user fuel dosing pump from rover JEX1000090 £78.00 Idea
Post #860143 6th Oct 2020 8:03pm
Matt110
Now that's a good plan.......! Thumbs Up
Is JEX a rover part number in that case as it's got a JEX number on the side of it.
I guess that cements the idea it's a 75 unit.
Post #860147 6th Oct 2020 8:14pm
dorsetsmith
Post #860148 6th Oct 2020 8:16pm
Matt110
Thanks Thumbs Up
If you look at that new part it's even the same shape as the one I've got, and doesn't match either the OEM ones from webasto or the Chinese copies.
Post #860149 6th Oct 2020 8:23pm
