Home > Puma (Tdci) > Fuel tank removal hints and tips
Co1
I need to replace the breather on my 2.2 90. I’ve read the sticky on here, but outside of that there is little that google can help with!! Any hints or tips for the process and anything else I should be doing while the tank is out?
Col
Post #858898 30th Sep 2020 8:24am
jst
i havent seen the sticky for it.
have a large pry bar handy and be prepared to manhandle it.
use a good quality fuel rated breather pipe.
take tow hitch if fitted off prior
some of them come out easy some takes ages.
remember - its a pain in the arse but people have done it so its doable. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #858924 30th Sep 2020 9:57am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Post #858926 30th Sep 2020 10:05am
One obvious but often overlooked point is to make sure that there is as little fuel as possible in the tank.
Post #858935 30th Sep 2020 10:50am
Co1
Cheers. Planning on getting some paint and dinitrol on the backside of the cross member while I’m at it and the underside of the rear floor. Is it worth fitting the guard out and replacing it to make life easier (this maybe be negated once I find out how much a new one is!!)
Post #858938 30th Sep 2020 10:54am
jst
i wouldnt change the guard unless fitting detachable towing guard or similar. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #858939 30th Sep 2020 10:54am
Co1
Yep, £140 from YRM. Will be taking the old one out very carefully!!
Can anyone recommend some decent quality hose that will do the job?
Post #858940 30th Sep 2020 10:55am
Co1
Here’s a thought. What about something like this to allow access from the top. It low profile enough to site flush with the sound proofing and with 180mm dia would provide enough space to get the FEO pump out in the future, but if I positioned above the fuel pump would I be able the reach the breather?
https://www.floatyourboat.co.uk/inspection...5QQAvD_BwE
Post #858964 30th Sep 2020 2:22pm
ChrisDefender
Hi,
I had this issue a year or so ago. Took me ages to find out anythng about it, and as some have done considered putting an accesss point in the floor. However, i didn't really fancy putting more holes in the thing so, afer much debate, stress and worry about what to do I took it to my local indie and he dropped it out, swapped all the bits over, rust proofed all the areas that can't usually be got at and put it all back - no bother at all. Oh, and the tank was less than a 1/4 full.
Obviously with ramps and all the kit its different to doing it yourself but afterwards I did wonder why I was so worried about it!
Post #858965 30th Sep 2020 2:42pm
jst
Iooked at these and for the mornings work it takes to do the tank I didnt want the hole in the floor.
Depends how many times you intend doing it! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #858966 30th Sep 2020 2:42pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
They are good quality though!. Rgds.
Chris
Post #858968 30th Sep 2020 3:07pm
Co1
Right O, tank out it is. That’s next weekend accounted for!!
Post #858969 30th Sep 2020 3:08pm
Co1
Any thoughts on what to replace the breather with? I don’t want to fit a genuine hose and have to do it again in a few years. Does anyone know the dimensions of it?
Post #859668 4th Oct 2020 7:36am
jst
Find some sae spec fuel line online, ebay? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #859671 4th Oct 2020 7:40am
jst
https://www.ebay.co.uk/itm/Rubber-Fuel-Hos...SwMEFfGvMl Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #859673 4th Oct 2020 7:42am
