![]() | Home > Puma (Tdci) > Stereo upgrade |
mines too... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548 ![]() ![]() ![]() |
Do Sony car stereos still do that annoying "beepity beep beep" thing after you switch the engine off, to remind you to remove the front plate?
![]() Thats probably the only reason I've not had a Sony one for years ![]() 2011 110 XS DC Stornoway Grey |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
Yep, but it can be turned off.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
Ah-ha.....thats probably always been the way, knowing me!
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
![]() Click image to enlarge Kenwood BT61U with Bluetooth, iPod / iPhone and USB, only thing it's missing is DAB, but at £170 it's a very good head unit. http://www.kenwood-electronics.co.uk/produ...KDC-BT61U/ |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 ![]() ![]() ![]() |
Good, I see I am not alone with my Kenwood KDC BT61.
BR Oskar |
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 ![]() ![]() ![]() |
how do you turn it off ![]() |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 ![]() ![]() ![]() |
So there are three of us ![]() Note - I had to update the firmware - the BT refused to work after few weeks. Now it's fine (Samsung Solid 2100). Janusz www.yahodeville.com |
Yep, I had to update the firmware to get it to connect - HTC Desire HD |
Mine has an ALM option on the menu... Not listed in the book! I can turn the beeps off from there, but being completely brain dead, I need the beeps to remind me to detach the front panel! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
Having heard the kids singing in the rear of the Puma, it makes me realise that the original Land Rover head unit is quite adequate after all.
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
Her Highness and Sirs, I object! There is no upgrading a stereo on recent defenders, as this requires something to be replaced! The surprise gift with a scale does not qualify for a stereo ... imho
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
Just got the truck back today from an audio upgrade done by John Kleis in Reading. I'm very very pleased with the sound - I like my music (club, pop, rock, jazz) load. If anyone is interested then the set-up that I went for is
Alpine CDE126 BT head unit Focal BUS20 active subwoofer under the rear seat Rainbow 4" component speakers in front/treeter Pioneer TSX150 3 way pod speakers mounted to the load guard above passenger head height Disconnect rear speakers but leave in situ iPod in cubby box The rear load guard mounted pods gets over the problem of the rear OEM speakers being covered up by items in the back (tents, sleeping bags, boxes etc) Under rear seat for the subwoofer gets over the vibration in the bum problem if you put the subwoofer in the under driver seat space - and you have a moderately better chance of keeping it dry if you go wading The rainbow speaker units handle 80W but their slim throw doesn't require thick mounting collars on the passenger side to keep away from the a/c/heater ducting there. Just got a few tweaks to do on the subwoofer gain and high pass filter settings just to confirm that I can't get anything more out of the system - but I've had a pretty big grin "kickin ass" and annoying the neighbours Problem now is I can't hear the engine and subwoofer makes the rear shock outter casing rattle ![]() Oh! And my ears have started bleeding ![]() |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2450 ![]() ![]() ![]() |
![]() Click image to enlarge These + 2x16cm in front doors makes a huge difference ![]() ............................................................. Earth first. Other planets later |
