![]() | Home > Series Land Rovers > clutch slip - time to replace? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
Hi Joseph, if clutch is slipping, unfortunately it will only get worse.
Higher gears will mean more load on the engine, hence the slippage on 4th and 3rd. Lower gears have a greater mechanical advantage. I doubt that the hydraulic system is the root cause. However, the master cylinder has a non return valve.. it should let any residual pressure in the clutch hydraulic system to relieve when the clutch pedal is up. But if the adjustment of the clutch pedal is not correct, the system can maintain pressure, forcing the release bearing on the pressure plate. Easy way to check this is to remove the slave from the bellhousing ( do not undo the hydraulic), and see if you can push the piston inside the slave cylinder. Doing so you will push oil back in the reservoir. Make sure you do not overflow the oil in the reservoir. The paintwork will not be happy with dot 3 or dot 4 oil. If the hydraulic is ok, then it will be an engine or gearbox out. Dont know which is easiest on a Series. If gearbox out, need to remove the seatbox. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17728 ![]() ![]() ![]() |
Sounds like time for a new clutch, certainly.
Generally on a series engine out is probably easier, with better access, easier lifting, and fewer corroded body fasteners to remove. |
MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137 ![]() ![]() |
Finally a long weekend to have a look into the clutch problem.
It was shot, worn down to the rivets. It managed to eat away at the pressure plate face. Flywheel side looks smooth but many hairline cracks. My feeling is pull it out and get it skimmed but engine looks like will need a rebuild soon. (next to no compression and burning oil) chassis patching and new oil seals for gearbox while all the bits are out ![]() Joe ![]() Click image to enlarge |
Hi,
clutch replaced. flywheel skimmed (0.1mm taken off - lots of cracks and a slight groove) it was already under by 1 or 2mm but been ok for the past 15 years so thought 0.1 would not matter. new bush, some chassis rust removed. seals on gearbox input/output shafts replaced. transfer case preload set to 4kg. clutch slave and master were replaced months ago. hand brake adjusted after heavy degreasing - just clicks 3 times and then it is tight to pull up. Clutch pedal is surprisingly soft (due to new pressure plate) System is free from air as it was not opened and kept topped up. gear engaging but not as easy and loosely as before - could be due to the tightened output shaft bearings - No clapping/clocking when shifting out of gears. occasionally when taking off there is a sound of rubbing metal (hissing) parts I did start torqueing the pressure plate with the wrench set to 65lbft, i realised that after the 2 bolt. The correct limit is 25lbft. is it possible to damage the friction material or pressure plate by such over tightening? I am thinking it might be hand brake shoes catching the drum at times. the drum feels cold to the touch after 10 mile runs. Thoughts? Regards. joseph |
No, you might strip the thread or shear the setscrew, but you won't have damaged the driven plate and you are unlikely to have damaged the cover. |
thanks,
I did not reach the 65lbft mark it just felt like not reaching a tight "spot" I put new 8.8 13mm bolts all around. Will see how it does ![]() |
