Home > For Sale & Wanted > [Wanted] LT230 High/Low Range Switch |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2225 |
Does anyone happen to have one of these switches lying around (maybe on a spare defender transfer box)? I have one fitted to mine but sadly seems to be a reverse light switch rather than the Hi/Lo switch as it is Normally Open rather than Normally Closed so works back to front. The new switches are nearly £50 which is ridiculous!
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
2nd Oct 2020 10:04am |
Brilliant thanks Simon, fingers crossed! 02' 110 TD5 Double Cab Rebuild Thread
2nd Oct 2020 1:23pm |
LR Sam Member Since: 08 Nov 2012 Location: Yorkshire Posts: 234 |
Is this the part number Steve?
If so the Lucas OEM one isn't very expensive? PRC2911 |
2nd Oct 2020 1:24pm |
Hi Sam,
No that looks like the diff light switch, it is the High/Low Range one that I am after which is only fitted on the later boxes: https://www.paddockspares.com/igm100000-switch-inhibitor.html Looks deceptively like the TD5 reverse light switch but works the opposite way around. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
2nd Oct 2020 1:30pm |
Ah apologies! That does seem expensive!
2nd Oct 2020 1:58pm |
V8Simon Member Since: 17 May 2016 Location: Prestatyn, Wales Posts: 146 |
Sorry Steve, I looked on the spare LT and there's no switch on it. 1984 90 V8 puma want to be.
5th Oct 2020 2:39pm |
