Home > Technical > ABS Ring
sjc501
ABS Ring
Hi After getting brakes and pads done my abs in one wheel is causing issues .We have narrowed it down to an abs ring issue .Question can you buy this separate ?
2.2 Puma 2013
Post #859280 2nd Oct 2020 9:18am
hank
No it's built/machined in to the driveshaft. What is the issue with the existing ring? Are you sure the issue lies with the ring itself? Have you checked the sensor gap?
 > 110 XS Double Cab
Post #859283 2nd Oct 2020 9:42am
hank
Post #859284 2nd Oct 2020 9:50am
sjc501
Hi Thanks for reply .Yes I had the abs sensor replaced .First with after market then secondly with Land rove part to make sure.Also had auto spark check abs pump etc .
Post #859285 2nd Oct 2020 9:50am
dorsetsmith
rear ABS ring
Post #859307 2nd Oct 2020 11:29am
sjc501
Found it it also 364 !!.Thanks
Post #859379 2nd Oct 2020 4:29pm
dorsetsmith
check wiring, abs sensor. too start with before the price thing
on my phone you have Idea
wheel bearing all good
Post #859390 2nd Oct 2020 5:00pm
sjc501
abs sensor
Hi Update on this saga . Changed the abs ring and its still the same . Getting a reading from all 4 wheels but the one with new ring different . Still get the abs light and grinding noise. U have now had the sensor changed twice and now the ring . Next step is to get the auto spark back .
Post #864732 1st Nov 2020 10:00am
