![]() | Home > Wheels & Tyres > Wheel Spacers |
Don't forget to tell your insurance company.
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Not a problem
Ratty Member Since: 19 Mar 2009 Location: Somerset Posts: 37 ![]() ![]() |
what size tyres are you running?
Wheel spacers can (in some cases) cause excess stress on wheel bearings. Offset/dished rims would be a better alternative as the load point on the hub is the same as standard, but you get the same improved turning circle. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5080 ![]() ![]() ![]() |
Adrian Flux just told me at renewal they didnt care about any modification or accessory that was in the land rover book of accessories (if they were/are the genuine ones), they noted them anyway for me
They are usually good normally, but this was a nice surprise, Mike |
They dropped my Range Rover insurance when I converted it to a Dakar ![]() |
Im using 285 BFG MT`s on boosts ![]() ![]() |
Yep same difference sonic
I was so p
Here is a diagram explaining offsets for those interested
You will suffer wheel bearing problems
![]() The later models have a shim or sleeve between the bearings and one nut that tightens it all up. Its a pain in the ass to set it all up. I know someone that has reverted to the old system that doesn't have the shim between the bearings, but does have the old style 2 nuts with a locking tab washer between them. This way he can, as a matter of routine maintenance check and adjust the bearings at his leisure ![]() Edit And with your wider track you will be putting more stress on the bearings when driving rutted tracks. ![]() |
She will be changed next year
