Home > Maintenance & Modifications > Defender 90 Puma intermittent starting. |
rich585 Member Since: 30 Sep 2020 Location: dorset UK Posts: 18 |
Just tried a start and got the click of death. Whack the Dash. Started! Hmmm maybe it is the dash connector solder joints....
30th Sep 2020 10:28am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8021 |
sounds like starter motor solenoid. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
30th Sep 2020 10:56am |
Except that whacking the dash appeared to clear the fault... will keep trying this to see if it's repeatable. If it is, then it's the dash soldering... |
30th Sep 2020 11:06am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I would start with the basics.
Is it not the starter solenoïde contacts? I don't have a Puma so don't know exactly how they are mounted. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
30th Sep 2020 1:23pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
It's a solder issue on the instrument cluster (like your Ford - similar problem).
See https://www.defender2.net/forum/post814212.html#814212 1988 90 Td5 NAS soft top 2015 D90 XS SW |
30th Sep 2020 1:38pm |
