Home > Technical > Defender Td5 ABS Issues
bankz5152
Morning chaps,
This has been on going for a while now and always suspected a dodgy sensor however now it has a Britpart G item and still doing it.
ABS/TC lights come on randomly and stay on. Sometimes clears on its own sometimes needs the nanocom.
9/10 says "front right output too low" occasionally says "electrical failure"
Tried wabco, cheap and britpart G all do the same thing. Anything else bar the sensor that can cause this fault? Instagram @defender_ventures
Empire Tuning - Agent
Post #858499 28th Sep 2020 6:23am
Wheel bearings was always a favourite. Darren
Post #858634 28th Sep 2020 8:52pm
bankz5152
Yup. Fronts are new(ish, sub 5k, Timken, no play) swivels have zero play as well Instagram @defender_ventures
Post #858638 28th Sep 2020 9:11pm
Wiring fault, high impedance connection (always a popular problem with f.o.s sensor on the Disco2).
Post #858640 28th Sep 2020 9:23pm
bankz5152
Ahhh handy! Whats the fix? Cut back as far into the loom as possible and run new line? Instagram @defender_ventures
Post #858656 29th Sep 2020 4:49am
On the Disco2 there was a service action to replace the entire sensor harness from the F.O.S sensor back to the SLABS ECU with a continuous harness, to replace the connector mounted on the F.O.S inner wing. I had to do this within weeks of the warranty expiring on my '02 D2 due to the three amigos.
Ironically last year I had to replace the F.O.S sensor and you cannot get replacement sensors with the extended harness any more, so I ended up reconnecting the original and previously disconnected harness and reinstating the supposedly troublesome connector on the inner wing.
It would probably be sensible to do a continuity and impedance check, and a visual inspection, of the wiring from the sensor connector back to the ABS controller, it might show something suspect.
I imagine that you have checked that the clearance between the sensors and the inductor rings on the hubs are correct?
Post #858678 29th Sep 2020 8:05am
TVR Tommy
United Kingdom 2000 Defender 90 Td5 Heritage LE Bronze Green
Check the earth to ABS control unit under the seat, nut could be loose.
Edited to say:
I read your whole post (should try that first) and probably not an earth fault with the error you describe
Post #858704 29th Sep 2020 9:23am
bankz5152
Thank you both. Ill check both.
Itll be fun considereing where the Defender ABS unit is Shocked Instagram @defender_ventures
Post #858876 30th Sep 2020 4:41am
