Home > Td5 > Coolant leak |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5858 |
Had a look todat the leak certainly appeared to be coming from the top hose/radiator end.
I went to remove the spring loaded clamp thingy and this snapped along a clean break without very little pressure. I made the assumption, that this was the source of the leak and replaced this with a jubilee clip. I need a good run now to see if this has resolved the issue. What is the current name of these clips and what would be the correct size to replace with? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
28th Sep 2020 5:24pm |
