![]() | Home > Technical > Folding rear bench seat release pull broken. |
![]() Click image to enlarge your pic |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 ![]() ![]() ![]() |
Can you take some more pictures? That looks nothing like the second row seats in my truck!!
Swiss Member Since: 27 Mar 2020 Location: Cisnidioara Posts: 3 ![]() ![]() ![]() |
Sure....I’ve added a picture of the good side that’s functioning.The Defender is LHD and originally from Germany.Not sure if they’re much different to the UK spec.I can take more pictures if you require.To be honest the good side does not function very well.If there’s a solution to replace both then I would probably be happier.But the biggest problem at the moment is I can’t drop the single seat.
Regards Tony |
Nutter Member Since: 15 Sep 2014 Location: Birchington Posts: 25 ![]() ![]() |
Hello you should be able to use a pair of long nose pliers or tweezers down the hole and pull on the broken rod, you may have to wiggle the seat as you pull it.
Part number MWC1614 link rod R.H Part number MWC1615 link rod L.H Part number MWC2722 plastic ring pull james |
Thank you James,very helpful.
Regards Tony |
izack98 Member Since: 25 Sep 2016 Location: Vancouver Posts: 26 ![]() ![]() ![]() |
Here's the parts list. I had the same issue in my LHD 110. I tried to get down in there with a pair of needle nose but didn't know what to grasp to pull. I may be able to now that I've had it apart and know what to pull.
I had to take out all the nuts and bolts that hold on the cover (Part #1). It was a bit tricky as the seat is in the way of some of the screws. I also took out the bolts (2 bolts) that connect the back of the seat to the seat cushion. Then removed the seat cushion frame (2 bolts). That helped. It turned out Part #7 was broken off at the top. I used a small diameter piece of cable about 6" long and looped it through part #21 and then crimped the 2 ends with an aluminum crimp and then fed it out through the slot in part #1. I replace all the hardware with stainless steel allen head bolts and nuts. It works fine [im ![]() Click image to enlarge g][/img] |
Great answer. Thanks for sharing. Darren
rdavisinva Member Since: 11 Sep 2020 Location: Chesapeake Posts: 5 ![]() |
Please post up a few pictures of the fix. Your description is good. I have the same issue and need to fix ours. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8165 ![]() ![]() ![]() |
These are not simple to fix, as above, the issue is getting access to the broken mech. Going in through the seat itself is required to get access to the mech mounting bolts. Its quite a typical failure , usually the plug pull lug breaks. A pain to fix as its time consuming but it's all very simple once you are in there Cheers
Swiss, I'm trying to upload a couple of pics for you but when I chose the pics it just says "Adding to Panel" and doesn't do anything more. I've searched posting pics and have followed the directions. Not sure what's up.
It may be that the pictures consume too large a storage space.
Will PM you with my email. Thanks for your efforts. |
