Home > Puma (Tdci) > Transferbox oil leak?
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
Hi guys
I recently purchased a 2011 2.4 Puma 90 and have noticed a small leak from what looks to be coming from the transferbox.
Not sure if anyone can tell from the photos, but doesnt appear to be obvious where its coming from. I dont think its the drain plug as there are drips higher up.
https://www.dropbox.com/s/76i08w8z4vh7wv2/...3.jpg?dl=0
https://www.dropbox.com/s/hcq3eg3d9672up5/...7.jpg?dl=0
Any advice is greatly appreciated about possible sources, thanks!
Post #858080 25th Sep 2020 1:21pm
hank
99% likely to be a worn case where the intermediate shaft locates. How many miles on your 90?
From ashcrofts website "The hole that supports the head of the intermediate pin in the LT230 casing is prone to wearing, and the pin elongates the hole so that it is out of round. This can lead to a transfer case whine, and an oil leak"
There are a number of options...
Do nothing and monitor oil level.
Cheap and cheerful - lather the area in instant gasket. The pin does not rotate so this may work in the short term. The previous owner did this to mine and it held up for a little while.
To properly resolve the issue is a transfer box off job unfortunately as the gearbox partially covers the intermediate shaft meaning you can't withdraw the intermediate shaft in situ to replace the seals.
I have read about people fitting threaded bar in place of the gearbox fixing bolts to enable the transfer box to be slid back just enough to change the intermediate shaft seals but I've not tried this myself.
Even once the transfer box is off you have a few options...
Replace the intermediate shaft o-rings - could last you a long while if your casing isn't too worn. See youtube vid below.
More expensive - replace with a rebuilt box but just be careful as the rebuilt casing could be just as bad as yours.
Labour intensive - rebuild box into replacement ashcroft sleeved casing. I have recently done this, it's the belt and braces approach and with a bit of luck will provide good longevity https://www.ashcroft-transmissions.co.uk/d...asing.html
I've also read about the Aussies modifying the case to accept a core plug as a seal.
 > 110 XS Double Cab
Post #858082 25th Sep 2020 1:49pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
I have similar issue, going to swap fluids first as mine has had some repair in the past for a leak on transfer case.
Then plan the attack Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #858086 25th Sep 2020 2:13pm
TamarBlue11
Thanks Hank for the detailed reply, there's just under 90k on the clock.
In the first instance I might apply some instant gasket and see how long that holds up as you suggested. I guess I would just use this in the area thats circled in your photo?
Post #858093 25th Sep 2020 3:13pm
hank
Indeed. You can see the one below has been sealed with instant gasket. Thing is the shaft/case where you want to access is largely covered by the gearbox output flange so you won't be able to seal it up fully in situ without disconnecting the transfer box from the gearbox. Right pain.
 > 110 XS Double Cab
Post #858095 25th Sep 2020 3:25pm
TamarBlue11
Makes sense, thanks for your help.
Will give the instant gasket a go tomorrow!
Post #858098 25th Sep 2020 3:35pm
ickle
use a good degreaser spray (mind your eyes) carb cleaner etc first, gasket goo on your digit and work it in around the area and you may be lucky for a while - IIRC I did mine in situ with longer studs, pulled the shaft partway out, changed the seals, added the goo and put it all back in place, still good 5 years plus later.
Good luck
Post #858099 25th Sep 2020 3:43pm
jst
One of mine leaks badly here. I am going long term fix and replacement t box from ashcrofts, with that bit sleeved and will also take opportunity to change ratios. 130 is heavy and tows a fair bit so will try out 1.3box. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #858258 26th Sep 2020 4:06pm
