![]() | Home > Puma (Tdci) > Does the breather system have any serviceable parts? |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 597 ![]() ![]() ![]() |
The bit I've arrowed in red, does that come off and what's under it if it does? Does that mean the breather system has a serviceable part, maybe the oil separator? It's not in the Hayes Manual (but then there's quite a lot not in the manual!).
Thanks. ![]() Click image to enlarge |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2324 ![]() ![]() ![]() |
The part arrowed is a plastic cover and can be prised off easily. Underneath it retains a sprung diaphragm which yes is part of the breather system but not really an oil separator. It's sprung in the open position so only closes on negative crankcase pressure (never?)
Mine was well baked and had gone hard and crispy so I fitted a new one. Land Rover don't list the diaphragm separately but you can get them... https://www.ebay.co.uk/itm/114273693389 The rocker cover kind of has an oil separator built into it. The fumes enter into a void in the cover at the front of the engine (circled green in below photo), pass through some galleries and then the gasses exhaust out at the rear (green arrow). Presumably the idea is that oily residue/suspended liquids are supposed to drop out of the fumes and run back to the rocker leaving only 'clean' fumes exhausting from the valve, but as we know this is rarely the case ![]() Click image to enlarge > 110 XS Double Cab |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1852 ![]() ![]() ![]() |
The cover stops the bonnet being dented when you forget to remove the bottle of beer before slamming bonnet.....If the cover is fitted you can't leave the beer there.
I actually bought one recently ![]() ![]() |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
Actually it does. It keeps JLR afloat.....
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Ah yes of course! The recess that it fills in the rocker cover has (drainage?) holes in the bottom of it, yet the cover has a sealing o ring on it? Go figure! > 110 XS Double Cab
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17726 ![]() ![]() ![]() |
I have an idea. If anyone thinking of buying one would like to send me £15 instead, they will save money and I will put it to a very good use!
garettb16 Member Since: 13 Dec 2020 Location: Melbourne Posts: 6 ![]() ![]() ![]() |
Hey Andy, I’m having similar problems to yours and am wondering where you are at with sorting them?
I too had leaking from the fuel pump cover at the front of the engine I had the injector seats cleaned and new washers and seals which has dramatically improved the car however it is still losing a small amount of oil from the same cover (cover has also been replaced out of precaution, I saw your before and after videos and mine was also similar with visible exhaust gases coming from the oil filler cap. I am now looking at the breather system in the valve cover thinking it might be restricted possibly, but with the engine running and the pipe removed (connecting to turbo inlet pipe) it does have mild blow by coming out, not smoky however. |
