Unswitched 12V socket in boot
I have bypassed the relay for the 12V socket located on the lower LH side of the trunk / boot, as I'd like constant power to my ARB fridge freezer when on a multi-day trip, without the juice cutting off along with the ignition as Land Rover intended.
The relay that powers off that 12V socket (and that socket alone - I've tested all remaining ones in the car, including front seats, second row sockets, USB ports and AC outlet in the boot - all of them keep shutting off along with the ignition after jumping, so they are obviously controlled by different relays) is located in the fuse box in the boot, under the plastic cover on the RH side panel. Yank that cover off, unclip and remove the plastic lid of the fuse box, and gently pull and remove relay R9. Bridge the contacts of the relay with a small piece of insulated electrical wire of decent gauge and two male spade connectors at each end to insert in the female receptacles where the relay used to be. There is also a handy guide attached to the left side of the fuse box, just in case.
I tested the fridge overnight in my garage, no problems. Here are photos of the fuse box, a close-up of the bypassed relay and the relay itself (the contacts to bridge are the larger two - one horizontal and one vertical - opposite each other.)
23rd Sep 2020 6:33am
weeman
Nice work, that will definitely come in handy.
Do you know what size / capacity the stock battery is?
23rd Sep 2020 7:29am
umbertob
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
