- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
umbertob
![](templates/vbnew/images/spacer.gif)
Park Brake - Service Mode Manual Activation / Deactivation | |
Not sure if this was posted before, from the workshop manual. You - or your mechanic - would follow this procedure if replacing rear brake pads and/or brake discs without LR diagnostics (which has a routine to do this automatically), to release and set the EPB in service mode, and back into regular operating mode after you are done servicing the rear brakes.
https://app.box.com/s/o9da83bhrxul9aniqk6j28ybx6d207j4
22nd Sep 2020 11:59pm |
Q86ARR
You also need to be aware that as new Defender does not have a brake booster, it has a brake booster module (BBM) this also needs to be put in service mode before ANY brake repairs are carried out
10th Oct 2020 8:19am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
