Home > Maintenance & Modifications > what dictates Brake caliper body renewal? + other question |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8145 |
i have used Zeus stainless pistons to good affect.
check price of new calipers as they may be cheaper than pistons + your time. order extra seal kits as outer dust seal is easy to damage. soak them in brake fluid prior to fitting. i just wire brush caliper, if its old 1980s1990s it may need replacing but if its 20years old or so i would of thought it would be fine ***subject to what its been submerged in**** unlikley it needs replacing. 4-5mm is quite a bit left, just over half way through? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
21st Sep 2020 11:43am |
MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137 |
Sorry not sure if they were uploaded in the initial post.
Here are the pictures. They should be 2003 Defender (AP) calipers. I do not go wading or do mud runs just regular road usage and occasional farm work in fields during hay season. No road salt either but salty atmosphere since the island is just 13miles x 7miles Click image to enlarge Click image to enlarge joe |
21st Sep 2020 11:58am |
i would wire brush them and leave them Cheers
21st Sep 2020 2:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17526 |
They look fine to me, I have seen many that are far, far worse than that on the outside.
21st Sep 2020 6:38pm |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 162 |
Im about to change my discs and pads and ended up buying a disc/pad/calliper set from Maltings for 200; at that price it seemed daft not to do it.
21st Sep 2020 6:52pm |
