- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
PCM
If you have a full depth Double din head unit, I found that you need to use a heat gun to 'squish' the air vents by about 5mm to allow it to seat properly. Not a big job but a pain. Hence the reason most go for the half depth units.
Others had already found this out before I did.
https://www.defender2.net/forum/topic54225-30.html
Good luck
18th Sep 2020 5:21am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
