Home > Td5 > Engine cover
bodstruck
Engine cover
Are the defender and disco td5 engine covers the same?
Disconones seem to me cheaper than defender ones and I wonder why. Clearly cheaper the better when I buy one.
Cheers.
Post #856707 18th Sep 2020 7:54pm
markb110
Probably the classic, its a Defender so charge what you like.
My wife had a Discovery 2 in the past , i cant think that there is a difference.
Post #856714 18th Sep 2020 8:13pm
grafty99
Defender and disco are definitely the same, I have a spare one off a disco that I plan on modifying before fitting - but it will fit as standard straight off a disco Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #856804 19th Sep 2020 8:54am
bodstruck
Excellent, thank you Thumbs Up
Post #856839 19th Sep 2020 10:15am
thinman21
United Kingdom 2004 Defender 90 Td5 HT Belize Green
Guess we could do with a parts interchange list somewhere so we know which Disco parts fit a Defender so we can check if they're cheaper.
Must be more than the engine cover thats a match.
Post #857160 21st Sep 2020 8:00am
Same with the in tank fuel pumps...
Disco used to be much cheaper than defender (don't know if this is still the case)
Just get a disco one, unclip the float arm and swap it with the float arm off of your defender pump
job done
Post #857187 21st Sep 2020 11:37am
htb2
Wales
Just bought a discovery 2 MOT failure for parts, what axle parts are swappable, rear shafts and front and rear diffs is all I can think of. To go onto a 05 110 td5?
Post #857253 21st Sep 2020 7:13pm
grafty99
Yeah that's about it for the axles I believe.
There's a few things I can think of off the top of my head but can't say with 100% accuracy
Air box is the same apart from the air in elbow which can be swapped for the defender one Thumbs Up
Front row interior lights
Headlamp level switch
3rd brake light
Heated front window switch
Heated seat switches
Swan neck tow ball is a good upgrade as it gives you more clearance with the spare (especially for alko friction stabilisers)
Gearbox*
Transfer box* (both need defender parts to swap onto them)
Bonnet stay
Exhaust downpipe
Steering box I think 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #857266 21st Sep 2020 8:07pm
htb2
Wales
Thanks Grafty, pretty much what I thought but no head lamp level on my defender.
Transfer box does not have the selector casting.
Rad similar but one pipe outlet different.
Post #857282 21st Sep 2020 8:48pm
