![]() | Home > General & Technical (L663) > Space under boot floor - 5 seat version - 110 |
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 175 ![]() ![]() |
I asked at the dealers, the two brackets behind the seats have to be bent out of the way and the foam pulled that way.
BearCZ Member Since: 03 Feb 2020 Location: Czech Republic Posts: 15 ![]() ![]() |
thanks for info.
i tried that after i get mine. i want in meantime to get the image of that space, so i can think how to use it |
JackW Member Since: 09 Jan 2017 Location: Roswell, Georgia Posts: 115 ![]() ![]() ![]() |
I'm thinking it might be a good spot for a second battery. I'm getting a P300 so the available space should be a little bigger than in the P400.
Foam and 2nd row removed - got this from FB
![]() Click image to enlarge ![]() Click image to enlarge |
StructuralDefect Member Since: 08 Aug 2020 Location: Middletown, Ohio Posts: 44 ![]() ![]() |
It would be the perfect place for someone's feet to go if you fitted some jump seats in the back. 2020 Defender S, P300 in Fuji White w/black ext. pack. Ebony leather heated front/rear seats. Comfort & conv. pack. Towing pack. Cold climate pack. Panoramic roof & expedition roof rack. Classic mud flaps. Fog lights. 19 inch 6 spoke w/off road tires. Clear sight rear view mirror. Sirius XM. Delivery 9/4/20
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2654 ![]() ![]() ![]() |
Structural
Are you saying that the space under the rear floor would be good for budding serial killers? ![]() Land Rover Defender 'Des' special ....... |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 ![]() ![]() |
It’s a big space, I’m sure you’d get the arms in there as well
Just testing the Defender under floor boot space....
![]() ![]() Click image to enlarge ![]() |
