![]() | Home > Puma (Tdci) > LOF HD rear half shafts? |
jbullis Member Since: 28 Apr 2013 Location: Jonesborough, TN Posts: 24 ![]() ![]() |
Just saw these yesterday. Anyone running a set that off roads your vehicle? Them seem to be priced very well?
https://lofclutches.com/shop/brakes/brake-...ve-shafts/ |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3348 ![]() ![]() ![]() |
Aren't those the Britpart ones? I'm told they are decent. WARNING.
This post may contain sarcasm. |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3698 ![]() ![]() ![]() |
They look like mine, and mine are britpart. Well made and seem to be coping well.
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 389 ![]() ![]() ![]() |
I fitted these. Very happy
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
So alternative aftermarket rather than specifically HD like Ashcrofts or GKN? Cheers
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 191 ![]() ![]() ![]() |
Installed the LOF ones last weekend, they did not arrive in blue bags.
Still, I am 99.99% sure they are the same as the Britpart ones. Same design and most probably same factory. I went for the LOF ones as I had confirmation the flanges were painted and was hoping it would be be a direct fit. Well .... the paint quality was so poor I could remove it with a finger nail, so I ended up removing all the poor paint and re painting. Luckily I had some leftover from a Buzzweld FXLiner 1k kit which was perfect for this. Anyway, britpart or not, they look very well made and once fitted, very happy with the improved driving experience so far! Hope they will last. ![]() Click image to enlarge ![]() Click image to enlarge /Mat |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
Shame about the paint, I'd give that feedback to LOF as I think they'd want to know.
Good that you're happy with them though ![]() Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 330 ![]() ![]() ![]() |
I know this is an old thread, but how are you getting on with these? Do you think they would be strong enough on a 110 overland vehicle?
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1144 ![]() ![]() ![]() |
deleted
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
No complaints with mine other than the paint quality is poor. In hindsight, I should have stripped and painted the flanges before fitting them. They've been fitted for almost 3 years now and have stood the test of time with no clunks / bangs appearing
![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Mine are all good. Fitted them, then gave then a whip over with some paint, given them plenty of abuse on and off road without issue.
Liam Murphy Member Since: 29 Jul 2020 Location: South Wales Posts: 95 ![]() ![]() ![]() |
Yeah second that, I have the LOF ones and the black paint doesn't even last 3 months before rusting through. I've just taken it back and painted with POR-15. If you get a chance do it before you fit.
As others have said, fit and forget. (but not the paint!) |
Great, thanks for the reviews. I think I'll get some on order, but will paint before I install.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1678 ![]() ![]() ![]() |
Does anyone know Are these more of an upgrade because they’re all in one or are they actually a stronger shaft?
